DC Motor Problem - Magnetic Field Calculation
The discussion centers on calculating the magnetic field generated by a horse-shoe shaped solenoid in a DC motor, which is crucial for predicting the motor's angular speed. The magnetic field can be calculated using the formula H = IN/l, where I is the current, N is the number of turns, and l is the length of the solenoid. The magnetic flux B is derived from B = μ0μrH, with μ0 being 1.2566 * 10^-6 Vs/Am and μr dependent on the core material. The user ultimately discovered that the professor provided a specific formula for angular speed, w = (V - Ir) / k * magnetic flux, rendering the magnetic field calculation unnecessary for their assignment.
  • Understanding of solenoid magnetic fields and their calculations
  • Knowledge of DC motor principles and operation
  • Familiarity with magnetic permeability and its significance in materials
  • Basic electrical engineering concepts, including voltage, current, and resistance
  • Research the application of Hall probes for measuring magnetic fields
  • Study the effects of back EMF in DC motors and its impact on performance
  • Explore different core materials and their magnetic permeability values
  • Learn about the relationship between magnetic flux and angular speed in motors
Students in electrical engineering, hobbyists building DC motors, and anyone interested in the principles of magnetic fields in motor applications.
Shahil
I really need help in calculating the magnetic field generated by a horse-shoe shaped solenoid which is being used as a permanent magnet in a DC motor.
The calculation is VITAL (well, I think so) as I need it to be able to predict the angular speed (in revs per minute) of my motor.
If there is sa way to do the prediction without this, I would gratly appreciate it.
FYI - We are being source a 10 volt, 2 amp current to make the motor spin. I need help ASAP as if my motor doesn't work, I fail this subject at University.
The magnetic field in a long solenoid is
H = IN/l, where
I is current,
N is number of turns,
l is length of solenoid.
I think you can use this, even though the solenoid is not straight.
The B field is
B = [mu]0[mu]rH,
where [mu]0 = 1.2566 * 10-6 Vs/Am.
[mu]r depends on your core material. Furthermore, it depends on how strongly the material is magnetized. OK, if you use a DC of 2 Amps, I should suspect that the core is always fully magnetized. At least in the stator. For iron, you can assume a maximum value of 5500. But be careful here, since other materials can have very different values of [mu]r.
I think the least risky method is, to measure B directly with a Hall probe.
Thanks!
thanks for the help on this problem. Your calculations made sense BUT (ironically and I think I got what I deserved 'coz I started researching so late) our prof gave us the exact formaula to use in our calculations!
w = angular speed
V = voltage
I = current
r = resistance
k = constant (taking account friction etc.)
(v - Ir) = back EMF induced by motor
Wen enquired about the magnetic field (B), he said it's not needed!
NOOOOOOOOOOOOOOO!
Anyway, FYI my motor spun at 900rpm, which was 200rpm slower than the winner.
thanks anyway:smile:
