Mangetostriction in antiferromagnetic materials
  • Context: Graduate
  • Thread starter Thread starter myhao
    Materials
The discussion revolves around magnetostriction in antiferromagnetic materials, exploring its mechanisms and comparing it with ferromagnetic materials. Participants share insights on the principles of magnetostriction, its dependence on crystal structure, and related phenomena, while also addressing a tangential question about nuclear magnetic resonance (NMR).
  • One participant expresses interest in understanding the mechanism of magnetostriction in antiferromagnetic materials and seeks advice.
  • Another participant suggests that the underlying principles of magnetostriction should not differ significantly between ferromagnetic and antiferromagnetic materials, although they admit to a lack of comprehensive references on the topic.
  • A detailed explanation is provided regarding how lattice constants are influenced by atomic interactions and how this relates to the magnetic moments of the material.
  • It is noted that the distortion of valence orbitals due to applied magnetic fields can lead to changes in lattice parameters, which is a key aspect of magnetostriction.
  • A participant mentions the ability to create a single magnetic domain in NiO by applying pressure, contrasting it with ferromagnetic materials.
  • Another participant introduces a question about the rf B1 field in NMR spectrometers, seeking clarification on its mechanism for flipping net magnetization.
  • A response indicates that NMR is unrelated to magnetostriction, suggesting a misunderstanding of the topic by the participant asking about NMR.
  • Further, a participant discusses calculating magnetocrystalline anisotropy energy in an antiferromagnetic alloy and raises questions about unit conversions related to magnetization and applied field.
Participants generally agree on the basic principles of magnetostriction but express differing levels of understanding and knowledge about specific mechanisms and references. The discussion about NMR is seen as tangential and not directly related to magnetostriction, indicating a lack of consensus on the relevance of that topic.
Some participants express uncertainty regarding the completeness of their understanding of magnetostriction and the lack of clear references. The discussion also highlights the complexity of unit conversions in the context of magnetocrystalline anisotropy energy calculations.
myhao
I am interested in mangetostriction in antiferromagnetic materials and the machanism of it, would you like to give me some advice? Thank you sincerely.
Questions like this are so broad that the best response would be "read chapter X from book ABC" or "read the review article by XYZ". Unfortunately, I know of no good references for magnetostriction...so I'll try a rough sketch.
From my very basic (virtually layman) understanding of magnetostriction, I do not see that there should be a difference in the underlying principle on the basis of whether the material is ferromagnetic or antiferromagnetic. I have not come across a very good (and complete) explanation for magnetostriction anywhere, that gives an intuitive understanding of the phenomenon. So, what I think I understand comes essentially from keywords picked up from sources describing calculations of the various components of the magnetostrain tensor, and what-not.
Hence, at best, I can talk about the origin of magnetostriction in the general sense. I'm not sure what level of understanding you seek (are you a grad student specializing in magnetostriction calculations for specific AFM compounds, or are you in college, etc ?), so I'll assume very basic knowledge. Here's my attempt at providing a semiclassical feel for the principle behind magnetostriction...
The lattice constants of an insulating crystal are determined by the various interactions between the atomic nucleii and the electrons (and take on those values that minimize the free energy comprising of all these interaction terms). To a reasonable approximation, the atoms may be treated as ions with valence electrons. Another not terrible approximation is to consider only the interactions between nearest neighbors (the farther away you go, the weaker the interaction). So, in short, one of the things that determines the lattice parameters is the interactions between the valence electrons (of any given atom) and the neighboring ions.
One of the outcomes of building a crystal out of individual atoms is that the valence electron cloud (probability density [itex]|\psi | ^2[/itex]) loses spherical symmetry, and now has a shape that minimizes the energy (a shape that reflects the crystal structure). The angular momentum of the valence electrons (which depends on the shape of this cloud) is thus a reflection of the crystal geometry. Since the magnetic moment (per ion) is a number proportional to the angular momentum of the valence electrons (classical equivalent : current loop has a magnetic moment; m = IA = (dq/dt)A = (e/T)A = ev(pi*r*r)/(2*pi*r) = (e/2)*r*v = (e/2m)*L, where L = angular mom. = m*v*r), this too depends on the crystal parameters. (Actually, in most materials, the total magnetic moment has a large component arising from the intrinsic electron spin, but this is also affected, due to spin-orbit coupling, which essentially makes the electron spin want to line up parallel to the orbital angular momentum). So, it would seem reasonable that altering the lattice parameters - which is the same as introducing a strain in the crystal - could change the way the magnetic moments want to point (by affecting the shapes of the electron clouds).
This is basically the inverse effect of magnetostriction (aka the Villari Effect), and says that applying stress to a magnetic material can change its magnetization. Reversing this line of thought explains magnetostriction, but needs to be done with a little care.
In the absence of an applied field, the atomic spins are lined up in some arbitrary (actually, they tend to orient along easy axes/planes, but a discussion of magnetic anisotropy is worthy of a whole thread by itself) direction (within a domain). Applying a magnetic field causes the spins to want to line up along the field. This causes the valence orbitals to distort so as to make the orbital moment line up parallel to the spins (and the applied field). The distortion of the valence orbitals causes the lattice parameters to change, which is seen as an effective strain in the crystal.
I remember reading that one could make single crystals of NiO a single magnetic domain by squeezing them between thumb and finger. This is not possible with a ferromagnet, of course, because ferromagnetic domains have an external field.
Otherwise, as Gokul writes, there is no real difference with ferromagnets. The mechanism works via spin-orbit coupling.
NMR rf Field
hi all,
could anyone help me explain how the rf B1 field in an NMR spectrometer works? Especially the mechanism it uses to flip the net magnetisation by an angle of 90 or 180 degrees?
Would be very gratefull for a link or and explanation to this.
Thanks
Wadings
NMR is about nuclear magnetic moments. It does not have anything to do with magnetostriction.
well i know about that but i was looking for a way to post a request. that is why. how can i create a forum?
Thanks, Gokul43201!Another question for the magnetic units.
Gokul43201, thank you!
Otherwise,i am calculating an antiferromagnetic alloy's magnetocrystalline anisotropy energy. The units made me confused. From the magnetization vs applied field curve (M-H curve), the integral difference value of the two M-H curves could be the magnetocrystalline anisotropy energy. However, the unit of magnetization is emu/g, and the unit of applied field is Oe(or kA/m) and the unit of magnetocrystalline anisotropy energy is erg/cm3(the third power). The volume unit of the sample, cm3, can be obtained.
How the units, emu, Oe (kA/m) transfer to erg? Is emu*Oe=erg?
Thank you again!
19K
10K
