How to derive the coefficient of thermal expansion?
The discussion focuses on the relationship between Young's Modulus and the coefficient of linear thermal expansion, establishing that they are inversely proportional. The derivation begins with the formula for strain due to thermal expansion, expressed as dL = L(a)(dT), where 'a' is the coefficient of linear expansion and 'dT' is the change in temperature. By substituting this expression into the Young's Modulus equation, Y = F/(A(dL)), it is demonstrated that Y is inversely proportional to 'a'. This conclusion is reached through basic principles of mechanics and material properties.
  • Understanding of Young's Modulus and its formula: Y = F/(A(dL))
  • Knowledge of thermal expansion concepts, specifically linear thermal expansion
  • Familiarity with basic mechanics principles, including stress and strain
  • Ability to manipulate algebraic equations to derive relationships
  • Study the derivation of thermal expansion formulas in materials science
  • Explore the applications of Young's Modulus in engineering design
  • Learn about different materials' coefficients of linear thermal expansion
  • Investigate the implications of thermal expansion in structural engineering
Students and professionals in materials science, mechanical engineering, and structural engineering who are looking to understand the relationship between thermal expansion and material properties.
tony_engin
Hi!
How to relate the Young's Modulus with the coefficient of linear thermal expansion? It is known that they are inversely proportional to each other, but how to prove this?
Hello,
It can be derived from basic principles. You can start by finding the strain caused by
the thermal expansion. The change in length for this part can be found by subbing in the thermal expansion formuale. Hence we have found the strain.
Y=stress/strain
=Fl/A(dl) where dl= change in length
I cannot proceed further than this due to lack of information on which kind of shape it have. ( to calculate A) However, the coefficient of thermal expansion could be seen to be inversely proportional to Y after subbing in the expression for dl.
Ok...For this you need to have a good grip on basic formulae
Since you are dealing with linear Young's modulus.First of all Young's Modulus for a wire of a specific material is given by:
[itex]Y= \frac{FL}{A (dL)}[/itex]
where dL=Change in Length
Now change is length due to linear expansion is given by:
[itex]dL=L (a) (dT)[/itex]
a=coefficient of linear expansion
dT=Change in Temperature
Now putting the values in Young's modulus equation:
[itex]Y= \frac{F}{A (a) (dT)}[/itex]
Therefore Y is inversely proportional to a...easy isn't it?
