Find the last digit of the sum of two numbers with large exponents.
  • Context: Undergrad
  • Thread starter Thread starter johnnyICON
    Exponents Numbers Sum
The discussion revolves around finding the last digit of the expression 222^{555} + 555^{222}. Participants explore various methods, particularly focusing on modular arithmetic to simplify the calculations.
  • Exploratory, Technical explanation, Homework-related, Mathematical reasoning
  • One participant suggests using modular arithmetic to find 555^{222} mod 100 and 222^{555} mod 100 to simplify the problem.
  • Another participant proposes finding the last digit by evaluating 222^{555} and 555^{222} mod 10 instead of mod 100, indicating this approach is simpler.
  • A participant describes their method of using mod 11 to find congruencies for both numbers, identifying patterns in the powers of 2 and 5.
  • One participant shares an example of finding the last digit of 7^{100} and questions if the last digit of their original problem can be inferred similarly.
  • Another participant explains the relationship between powers of 2 and their congruences mod 10, referencing the Chinese remainder theorem.
  • There is a discussion about the correct interpretation of modular equivalences when reducing exponents, with participants clarifying how to express these relationships accurately.
Participants express various methods and approaches to the problem, but there is no consensus on a single solution or method. Multiple competing views remain regarding the best approach to find the last digit.
Some participants mention specific modular bases (like 10, 11, and 100) and their implications for the calculations, but the discussion does not resolve the dependencies on these choices or the assumptions made in their reasoning.
johnnyICON
Hi, I am trying to solve this question in my textbook. It asks me to find the last digit of the following expression:
[tex]222^{555} + 555^{222}[/tex]
Now, I have tried using modular arithmetic to solve this question, but I'm stuck.
And I'm not all too sure if took the right approach or not, any hints?
You should be able to do the two terms separately, can you find 555^222 mod 100? 222^555 mod 100?
It might make the arithmetic a little easier if you consider powers of 2, 5, and 11 mod 100 separately but this isn't mandatory.
I did something like that. I used mod 11 for both numbers. Found 222 congruent to 2 mod 11, and 555 congruent to 5 mod 11.
So I made the statement that [tex]222^{555} \equiv 2^{555} mod 11[/tex]and [tex]555^{222} \equiv 5^{222} mod 11[/tex]
Then, I did successive powers of both 2 and 5 and found their congruencies until I found a pattern.
I determined that after five successive powers of 5, the congruencies would repeat. And after ten successive powers of 2, the congruencies would repeat.
So I divided the the exponents 222 and 555 by 10 and 5, respectively, to find another congruency. And that's where I get stuck.
Sorry, I was misleading in my last post. For some reason I thought you wanted the last two digits, not just the last one. To find the last digit you need only find 222^555 and 555^222 mod 10, which will be easier than finding them mod 100. This also means the bit about 11 is superfluous.
Maybe you can take a look at this example:
Example. Find the last digit of [tex]7^{100}[/tex].
We need to evaluate [tex]7^{100}[/tex] (mod 10). Since [tex]7^2[/tex] = 49[tex]\equiv[/tex] −1 (mod 10) we have [tex]7^{100} \equiv (72)^{50} \equiv[/tex] (−1)[tex]^{50} \equiv 1[/tex] (mod 10).Thus the last digit is 1.
Is the last digit 1 because of the last congruency?
Yes, the last digit of 7^100 is 1 because they've shown that the remainder you get when you divide 7^100 by 10 is 1.
So you look at the powers of 2 and find the pattern is 4 digits long. So 2^1, 2^5, 2^9, 2^13, ...2^105, ... are all congruent to 2 mod 10. Essentially you can add a 4 to the exponent and not affect the result. Same with 2^2, 2^6,... In the language of congruences, if [tex]a\equiv b\ mod\ 4[/tex] then [tex]2^a\equiv 2^b\ mod\ 10[/tex]. There is a good reason why this is true, a power of 2's congruence class mod 10 is completely determined by its congruence class mod 5 (Chinese remainder theorem if you've met it) and we know [tex]2^4\equiv 1\ mod\ 5[/tex].
In the link you provided, they have [tex]a\equiv b\ mod\ 4[/tex] implies [tex]7^a\equiv 7^b\ mod\ 10[/tex] (we actually know here [tex]7^4\equiv 1\ mod\ 10[/tex]). So to find [tex]7^{358}\ mod\ 10[/tex] notice [tex]358\equiv 2\ mod\ 4[/tex] so [tex]7^{358}\equiv 7^2\equiv 9\ mod\ 10[/tex].
Wow, that makes a lot of sense now. And thanks for relating to the link I provided. I was really uncertain about this part::
shmoe said:
notice [tex]358\equiv 2\ mod\ 4[/tex] so [tex]7^{358}\equiv 7^2[/tex]
When I divided the exponent by the length and found its congruence, I wasn't sure if it meant that [tex]7^{358}\equiv 7^2[/tex] or if it meant [tex]7^{358}\equiv 7^{2 (mod 4)}[/tex].
So when dealing with congruencies, I can replace a with b by symmetry right? That is, [tex]358\equiv 2\ mod\ 4[/tex] is equivalent to [tex]2\equiv 358\ mod\ 4[/tex].
[tex]7^{358}\equiv 7^2\ mod\ 10[/tex] would be the correct one. You don't usually put "mod" up in an exponent.
Yep. The "modular equivalence" works in many ways like your usual equal sign. It's symmetric, transitive and reflexive.
Great! Thanks a lot shmoe, you've helped a lot! Too bad I couldn't rate your help.
10/10
  • · Replies 16 ·
  • · Replies 28 ·
