Triangular numbers and v-t graph
  • Thread starter Thread starter lwymarie
    Graph Numbers
The discussion centers on calculating displacement using a velocity-time (v-t) graph in the context of uniformly accelerated motion. The correct displacement is derived from the area under the v-t graph, which totals 150 meters. The acceleration is confirmed to be 0.75 m/s², leading to a displacement calculation error in the original post. The correct formula for the sum of the first n integers is n(n+1)/2, which clarifies the total displacement as 157.5 meters, consistent with the v-t graph analysis.
  • Understanding of velocity-time (v-t) graphs
  • Knowledge of uniformly accelerated motion principles
  • Familiarity with the formula for the sum of consecutive integers
  • Basic proficiency in kinematic equations
  • Study the derivation of displacement from v-t graphs
  • Learn about kinematic equations for uniformly accelerated motion
  • Explore the concept of triangular numbers in mathematical contexts
  • Practice problems involving area calculations under curves
Students studying physics, educators teaching kinematics, and anyone interested in understanding the relationship between velocity, acceleration, and displacement.
lwymarie
http://student.shcc.edu.hk/~s021107/phy.GIF
Displacement=area under v-t graph = 150m
using another concept,
the acceleration is 0.75m^s-2, so the displacement at
1s=0.75m
2s=0.75*2m
20s=0.75*20m
total displacement =sum of displacement of every second
=0.75*(1+2+3+...+18+19+20)
=157.5m
Can you tell me wt's wrong here?
Your link isn't working, but I assume you are describing uniformly accelerated motion starting from rest.
Since [itex]v = at[/itex]:
At t = 0s, the speed is 0 m/s
At t = 1s, the speed is 1*.75 = 0.75 m/s
At t = 2s, the speed is 2*.75 = 1.5 m/s, ... etc.
To find the displacement during each second, use [itex]\Delta d = v_{ave} \Delta t[/itex], where the average speed equals [itex]v_{ave} = (v_i + v_f)/2[/itex]. Add these displacements and you'll find that they total to 150m.
Thank you for sharing the link to the v-t graph and discussing the concept of triangular numbers. The displacement of an object can indeed be calculated by finding the area under the v-t graph, as you mentioned. However, in your calculation of the total displacement, there seems to be a mistake. The formula for the sum of consecutive integers from 1 to n is n(n+1)/2, not n(n-1)/2 as you used. So the correct calculation would be 0.75*(1+2+3+...+18+19+20) = 0.75*210 = 157.5m. This aligns with the given displacement of 150m, showing that the object has not moved in the opposite direction and the v-t graph is consistent with the given information. It's important to check our calculations and formulas to ensure accuracy in our results.
  • · Replies 26 ·
  • · Replies 49 ·
10K
