Total energy, mass, and momentum.
The discussion revolves around calculating the mass, momentum, and energy of an electron moving at a speed of 0.8c, given its rest energy of 0.51 MeV. Participants are exploring the relationships between these quantities in the context of relativistic physics.
  • Some participants question whether it is necessary to use the provided rest energy value to derive the mass, momentum, and energy. Others suggest that the rest energy is integral to the formulas being referenced.
Participants are actively engaging with the problem, with some offering guidance on the relevance of the rest mass of the electron. There is an exploration of different approaches to the problem, but no explicit consensus has been reached regarding the necessity of the given rest energy.
There is a mention of external resources that may aid in understanding the relevant formulas, and some participants note the importance of the rest mass in the context of the equations being discussed.
Jchem
An electron with speed 0.8c, has a rest energy of .51MeV.
What are its mass, its momentum, and its energy (including rest energy)?
Ok, isn't it possible to get the three answers without using the .5MeV ?
I have 3 formulas for mass, momentum and total energy that don't use the .5Mev
but then I feel like I might be doing something wrong since they gave me the value.
Im not sure how to post the forumlas, but they are on this page
http://galileo.phys.virginia.edu/classes/252/energy_p_reln.html
thanks for any help
The rest energy is the [tex]m_0c^2[/tex] part of the formulas found on that page. Also, hyperphysics ( http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html ) is the #1 most helpful site I have found when I need to reference something. You will probably understand the formulas a little better if you look at the sections dedicated to relativistic energy there.
thanks for any help
The only way to avoid using the given information is if you know the rest mass of the electron. Look at the E equation in the limit of zero velocity. What is it telling you?
OOPs too late again. It's still the right question, and now you have the answer :smile:
You don't need that 0.51 MeV.Just that
m_{el}~9.1*10^{-31}Kg.
Daniel.
  • · Replies 23 ·
