How Is Internal Energy Affected by Friction in Physics Problems?
The discussion revolves around a physics problem involving a block being dragged over a rough surface with friction. The original poster is attempting to understand how internal energy is affected by friction in this context, particularly in relation to the work done by various forces acting on the block.
  • The original poster describes their approach to calculating work done by different forces and expresses confusion regarding the relationship between friction and internal energy. Other participants question the calculations related to the normal force and the application of the coefficient of kinetic friction.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made. There is mention of potential calculation errors and the need for careful consideration of angles in the context of the forces involved.
Antepolleo
I'm having trouble solving a problem related to work done on an object with friction present. Any help would be appreciated. Here's the question:
A 15.0 kg block is dragged over a rough, horizontal surface by a 82.0 N force acting at 20.0° above the horizontal. The block is displaced 5.50 m, and the coefficient of kinetic friction is 0.300.
a) Find the work done on the block by the 82 N force.
This was easy enough. Since the force is constant, I used the equation [sum]W = F*d*cos([the]). I got the right answer, which was
423.8014 J.
b) Find the work done on the block by the normal force
and
c) Find the work done on the block by the gravitational force.
Since the displacement in the vertical direction was 0, no work was done by these forces.
Here's the part that I'm having trouble with:
d) What is the increase in internal energy of the block-surface system due to friction?
I figured that since friction is not a conservative force, I could say that the increase in internal energy would be equal to the work done by the frictional force. I was wrong, and I'm not sure what concept I'm missing here.
Now I'm really baffled. I've just read several sources which tell me the energy loss due to friction should equal the work done by friction, which would be, if I'm not mistaken, μk*n*d.
μk - coefficient of kinetic friction
n - the normal force, which I believe would be m*g - F*sin(θ)
d - distance over which the force has acted
Can someone shed light on this for me?
edit - I'm really loving these math symbols, I don't see these on many forums.
Lord I'm such a dork.
"the increase in internal energy would be equal to the work done by the frictional force"
I'm no physics prof. (as you know) but this makes perfect sense to me. :)
I'll second that.
Are you turning it into a computer? If so, go through the calculations once more and check your sig figs. Computers are snippy with those.
I found the problem. I was using an incorrect theta. I plug all this stuff into MATLAB so I had to change the degrees into radians... I made a slight calculation error.
Thanks for the help!
Wait why is m*g - F*sin(θ) = n ?
I thought it was m*g*cos(θ)
  • · Replies 58 ·
  • · Replies 32 ·
