Light, Mirrors, Lenses, immediate help required
The discussion revolves around solving an optics problem involving a concave mirror. The user, mhl, is tasked with finding the image distance (di) when an object 24mm high is placed 12 cm from the mirror, given that the sun forms an image 3 cm from the mirror. The solution involves using the lens/mirror equation 1/f = 1/do + 1/di and the magnification equation m = -di/do = hi/ho. Ultimately, it is determined that the object must be placed 24 cm away from the mirror to achieve the desired image distance.
  • Understanding of the lens/mirror equation (1/f = 1/do + 1/di)
  • Familiarity with the magnification equation (m = -di/do = hi/ho)
  • Knowledge of concave mirror properties
  • Basic skills in algebra for solving equations
  • Study the properties of concave mirrors and their focal lengths
  • Learn how to derive and apply the magnification equation in optics
  • Explore practical applications of concave mirrors in real-world scenarios
  • Practice solving various optics problems involving mirrors and lenses
Students studying physics, particularly those focusing on optics, as well as educators and anyone needing to solve problems related to concave mirrors and image formation.
mhl2188
Hello, here is the problem i am having trouble with. The sun falls on a concave mirror and forms an image 3 cm from the mirror. If an object 24mm high is placed 12 cm from the mirror, where will its image be formed? So far, i have decided that since 1/f = 1/do + 1/di...
1/f = 1/do + 1/3 = 1/12 + 1/di
I also decided that hi/2.4 = -di/12... The problem is...even if i solve for di in terms of hi and plug that into my first equation i don't have enough information to solve for do. I am stuck and this problem is due tomorrow... please help
thanks
mhl
thanks
mhl
You need to use the "sun" information to find the focal length of the mirror. The sun is an object at distance ___________ that forms an image at 3cm. What is f?
Hello mhl,
Thank you for reaching out for help with your problem. It seems like you have made some progress in understanding the problem and utilizing the lens/mirror equation 1/f = 1/do + 1/di. However, you are correct in realizing that you do not have enough information to solve for do.
To solve this problem, we need to use the magnification equation, m = -di/do = hi/ho. This equation relates the height of the image (hi) to the height of the object (ho) and the distances of the image (di) and object (do) from the mirror or lens.
Since we know the height of the object (24mm) and the height of the image (3cm = 30mm), we can set up the equation as follows:
m = -di/do = hi/ho
m = -30/do = 30/24
m = -5/4
Now, we can use this value of m to solve for do:
m = -di/do
-5/4 = -30/do
do = 24 cm
Therefore, the object must be placed 24 cm away from the concave mirror in order to form an image 3 cm away from the mirror. I hope this helps and good luck with your assignment!
  • · Replies 16 ·
