How to build a Large electromagnet?
  • Context: High School
  • Thread starter Thread starter cb767
    Build Electromagnet
The discussion revolves around the construction of a large electromagnet, focusing on power supply options, wire specifications, and design considerations. Participants share their experiences, challenges, and suggestions related to building electromagnets for various applications, including specific shapes and lifting capacities.
  • Homework-related
  • Caleb expresses uncertainty about how to obtain a suitable power supply to achieve sufficient amperage for his electromagnet, which he plans to build using 2500 feet of 19 gauge magnet wire and an iron core.
  • Some participants suggest that the configuration of the windings (tightness and uniformity) may influence the electromagnet's strength, questioning whether a short and fat design is better than a long and skinny one.
  • Caleb mentions issues with his regulated power supply, specifically that he cannot adjust the current when the electromagnet is connected, prompting inquiries about alternative power sources.
  • Alternatives to a power supply discussed include batteries, solar panels, and generators, with a warning about the dangers of using car batteries.
  • Marlon suggests studying hysteresis curves and questions whether a hard or soft magnet is needed, indicating that material choice is important for performance.
  • Caleb indicates he is using iron and is concerned about the cost of materials with high saturation levels, while expressing confusion about the functionality of his power supply.
  • Erick provides insights on the resistance of wire and suggests using a higher diameter wire to reduce resistance, which may help achieve the desired current output.
  • Another participant describes a project involving wrapping copper wire around a car wheel and using an alternator as a power source, aiming to create a strong magnetic field.
  • John clarifies misconceptions about the effects of strong magnets on human health, emphasizing that the iron in blood is not ferromagnetic.
  • Bob S discusses wire specifications and provides a formula for estimating the magnetic field, asking for further details about the magnet's dimensions and desired field strength.
  • Several participants express interest in building electromagnets for specific applications, such as a magnetic bed or a scrap pickup attachment for a skid loader, indicating a range of project goals and resource limitations.
Participants generally share ideas and suggestions, but there is no consensus on the best approach to building the electromagnet or the optimal power supply configuration. Multiple competing views and uncertainties remain regarding design choices and material specifications.
Some participants mention limitations in resources and knowledge, indicating that their projects may be constrained by budget and available materials. There are unresolved questions about the specific requirements for current and voltage in relation to wire gauge and coil design.
This discussion may be useful for hobbyists, students, or anyone interested in building electromagnets for practical applications, as well as those seeking advice on power supply options and design considerations.
cb767
I need to build an electromagnet. I have 2500 feet of 19 gauge magnet wire, and an iron core available. I'm not sure how to get a power supply that would supply enough amps to make the magnet strong enough... Anyone have any suggestions?
Caleb
Considering that you can buy an electromagnet that lifts 500 pounds and runs on 2 'D' cells, I don't really think that it's a problem. Just make sure that your windings are tight and uniform. I don't know if number of layers vs total turns makes any difference. ie: Is short and fat better than, worse than, or equal to long and skinny?
Well, my main reason for building the electromagnet is because I need it of a certain shape. The primary problem that I've encountered is that this: I bought a regulated power supply. It has two adjustable knobs, one for voltage, and another for current. The strange thing however, is that I can't adjust the current once the thing is hooked up... I was just wondering if there were any alternatives to using a power supply out there that people knew of...
Pretty much the only alternatives are batteries, solar panels, or a generator. If it's amps you want, hooking it up to a car battery could probably suck the iron out of your blood. (If you choose to use one, be very careful. They can kill you, and one that isn't totally sealed can spill acid on you and releases hydrogen.)
Caleb
you really need a material of which the remanent magnetization is as big as possible...start studying some hysteresis curves, that is my suggestion to you
Will you be needing a hard or a soft magnet ?
marlon
I making it out of iron, so I believe it should be a hard magnet. I've looked up materials with high saturation levels, but unfortunately, they are two expensive for my budget. It turns out that right now, I have all of the equipment I need, but I think I'm doing something wrong with my power supply. The following links provide a few pictures of it:
http://i14.ebayimg.com/02/i/04/15/f7/e4_1_b.JPG
http://i1.ebayimg.com/02/i/04/17/6f/33_1_b.JPG
http://i2.ebayimg.com/01/i/04/17/9c/d2_1_b.JPG
When I hook the electromagnet up to it, I get no reading for current. If I hook two heavy gauge wires to each of the terminals and flip it on, I can change the amperage to whatever I want... I'm not sure what's going on. The dials say it's capable of 25 amp output and 10 volt output DC. Anyway, If anyone has any suggestions as to why it would work with just the two heavy gauage wire connected together, and not with the solenoid hooked up, I would really appreciate it.
You have a lot of options. The main thing you need to do is to get a better handle on your current requirements, then you can pick or design a suitable power supply. Without knowing what current range you need, it is difficult to recommend any specific power supply design or source.
If your existing power supply has the capability of supplying the current, you can probably just put a series current limiting resistor in with the circuit, then you will probably be able to adjust the current - the problem is that you apparently can't adjust the current into a dead short, if you put some series resistance in the circuit, you'll probably be able to adjust the current.
To get 25 amps out of a dc supply of 10 volts the resistance of your coil must not be higher then 0.4 ohm.
I don't know which wire is used but a copper wire of gauge 34 (= diameter of 0.1601 mm) has 0.833 ohm for every meter. So even half a meter of this product is already too long.
You will have to reduce the number of windings and use a higher diameter wire for this power supply. Product I*N will probably remain the same but the resistance will be much reduced.
I hope this will help, best of luck,
Erick
Am doing something similar to that. I have decided to get about 300 feet of copper wire and wrap 12 oval shaped coils around a car wheel that I will then attach to the hitch on the back of a truck. The power source will be an alternator, which will take place of the secondary air in on the drive belt. If I idle the truck, a small amount of energy will be made, but the energy will pass through the copper wire around the wheel and create a very large amount of energy. It will be magnetized enough to pick up a small car.
The iron in your blood is not arranged in a form that is ferromagnetic. It's actually very slightly diamagnetic, but not enough to matter. The superconductive magnets in an MRI don't have any affect on tissue at all, and some of the strongest special-purpose magnets in the world have been used to levitate living frogs and other samples, with no ill effects.
Any magnet you make won't hurt you, except by throwing other objects at you.
--John
Wire tables show the maximum current in 19 Ga. wire to be about 1.8 amps, and the resistance about 8.2 ohms per 1000 feet. The best magnet design is a "C" magnet or an "H" magnet, either with two coils. The coils (in series) would each be ~ 1000 ft long and I2R = 27 watts. For a tightly packed coil, the power should probably be closer to about 10 watts (or 1.1 amps), and 18 volts total. What insulation do you have on the wire, and what is its maximum temperature rating?
Very roughly, the magnetic field in the gap is about
B = μ0NI/g Tesla
where μ0 = 4 π x 10-7 Henrys per meter, N = total # of turns in both coils, I = current (amps), and g = gap (meters).
What are dimensions of your magnet, and what magnetic field do you want?
Bob S
I am 14 years old, and limited in rescources, so if anyone has any ideas how i could make an extremely powerful electromagnet (90 pounds of lift) that would be really great and I would thank you very much.
Okay I read in one of the lines that you can buy an electron magnet that will lift 500 lbs I want to build an magnetic bed and I need help with the magnet part if anyone can help me with this part that would be outstanding. you can email me at pearisjm@yahoo.com I am hoping to turn this into a great science project at the school that I work at also. Thank you for the help all
hey where can I buy this magnet that you are talking about because I am hoping to get two to life a bed in my room to sleep in do you have any ideas pearisjm@yahoo.com
I am new here and hope somebody can help me. I am wanting to build an electromagnet attachement to go on my skidloader for picking up scrap. The ones I have seen built for this purpose are approx. 16-20k. I am not willing to spend that much and believe I can make my own much cheaper. I would like to use an old 3500 watt generator head that is on a cheap generator I bought at a Walmart type place. My plan is to take a truck wheel and wrap the wire around it and use a hydraulic motor to power the generator head. I would like to be able to have at least one outlet on this magnet that could be used for 110v applications if needed. The high priced ones I have looked at are that way.
I'll get to the point now. I don't know how to figure out what size of hydraulic motor I need, how many wraps of wire and so on. Is there anybody on here that could possibly help me out.
Thanks,
Shaun
  • · Replies 42 ·
  • · Replies 22 ·
