Can TV Static Detect Cosmic Microwave Background Radiation?
  • Context: High School
  • Thread starter Thread starter Mariko
    Cmbr Set
The discussion centers around the idea of whether television static, often referred to as "snow," can detect cosmic microwave background radiation (CMBR). Participants explore the relationship between the frequencies of television signals and the characteristics of CMBR, touching on concepts from cosmology and signal detection.
  • Some participants suggest that the static seen on TVs is a result of picking up energy from the Big Bang, specifically CMBR.
  • Others discuss the frequency ranges of television signals, mentioning VHF and UHF bands, and relate these to the microwave frequencies of CMBR.
  • One participant recalls a popular science lecture stating that a small part of TV static is due to CMBR, but questions the details provided in such lectures.
  • It is noted that detecting CMBR on Earth is complicated due to interference from other microwave radiation sources, particularly from the Sun and distant stars.
  • Some participants argue that while CMBR has a defined temperature of 2.725 K, the proximity and intensity of solar radiation complicate its detection in the static.
  • There is a discussion about the need to integrate the blackbody spectrum of CMBR to understand its contribution to TV static compared to other noise sources.
Participants do not reach a consensus on the extent to which CMBR contributes to TV static, with multiple competing views on the influence of solar radiation and the challenges of detection remaining unresolved.
The discussion highlights limitations in understanding the relative contributions of various noise sources to TV static, as well as the complexities involved in measuring CMBR against other radiation.
Mariko
Nice Topic and info Nick! I heard that when you turn your T.V. on and you get that snow or in otherwords no reception that, the T.V. is picking up is acctualy some sort of energy from the Big Bang.. what do you think?
Astronomy news on Phys.org
May I add my support and congrats too - this is excellent!
Would you like to do a little digging on your own Mariko?
Do you know, when a TV set is tuned to station x, what the frequency is of the radio waves it's picking up? You've probably heard of VHF and UHF - do you what they are?
You've no doubt read that the 'cosmic microwave background radiation' (CMBR) pervades the universe, and was 'created' when the universe was only a few hundred thousand years young. You may also have read that it has a 'temperature' of 2.7K. The 'microwave' part gives you a clue as to the frequency , and the 'temperature' to the distribution of the frequency (it's a 'black body').
Putting two and two together ...
Yes I would! :biggrin:
The radio wave frequency of station X = 8-12 GHz
VHF and UHF are one of the bands that make up the electromagnetic spectrum. Here are the diffrent bands in order starting with the highest frequency:
Gamma rays, X-rays, ultraviolet, Visible, infrared, microwaves, UHF VHF,Short wave radio and long wave radio
Here is a quick summary of the names we humans have agreed to use for various parts of the radio/microwave spectrum, and http://map.gsfc.nasa.gov/DIMES/dimes_spectrum.html is a nice summary of the cosmic microwave background spectrum, including its intensity and where various observations have been made (note that, confusingly, the axes go in opposite directions).
I remember attending a popular science lecture a few years back where the speaker said that a small part of static (i.e, "snow") is due to the CMBR.
As it was a popsci lecture, the speaker may not have given any details ... do you think we could work this out for ourselves?
I've moved Mariko's idea forward a bit ... would you like to continue Berislav?
Okay. :)
It is notoriously difficult (if not impossible) to detect the CMBR on Earth. This is because it interferes with other microwave radiation. But that only makes it difficult to determine the exact origin of the signal, not to detect the signal itself, which interfered, of course.
Cosmic noise is a well known phenomena in signal noise research:
Cosmic Noise
As mentioned it the article most of it arises from radiation emmited by the sun and distant stars. This because the Sun's radiation has a longer wave-lenght than the CMBR:
http://en.wikipedia.org/wiki/Cmbr
The CMBR has the characteristics of black-body with temparature 2.725 K, while the Sun has the characteristics of a black-body with temparature 6000K (if I recall the temparature correctly).
So a small part of the noise one detects with their television will be from the CMBR.
I will try to find out more about this.
Theoretically, yes, but the difficulty would be in figuring out all of the other sources of noise. Determining the level of the CMB in that frequency range is simply a matter of integrating the blackbody spectrum, but the important thing for answering the question is how it compares to the rest of the static.
Most of the sun's radiation is of a much shorter wavelength than the CMBR, but it's so close and bright that it contributes a sizable amount of noise even in the microwave regime.
The temperatures you quoted are right, but that's not enough to determine that the CMB should contribute a small amount relative to the sun (or other sources). You need also to consider proximity, surface area, and directionality (for example, the sun won't contribute at night).
Yes, of course. :redface:
One can see that by observing Wien's law and the temparatures of the two:
[tex]\lambda=\frac{C}{T}[/tex]
where C is a constant.
