Covalent bonding has limited range?
Covalent bonding typically occurs in lower quantum energy states, with dihydrogen molecules often found in the first or second lowest quantum states at room temperature. While theoretically, electrons can occupy higher quantum states without immediately splitting the molecule, practical limits exist in air due to energy constraints. The discussion highlights that only the ground state is stable, and any deviation leads to molecular instability or decay. The concept of long-range covalent bonding is challenged, as most atoms do not possess electrons in high orbitals.
  • Understanding of quantum energy states in molecular chemistry
  • Knowledge of covalent bonding principles
  • Familiarity with molecular stability and decay processes
  • Basic concepts of electron orbitals and their energy levels
  • Research the implications of quantum energy states on molecular stability
  • Explore the characteristics of covalent bonds in different environmental conditions
  • Investigate the behavior of electrons in high energy orbitals
  • Learn about the limitations of covalent bonding in various molecular structures
Chemists, physicists, and students studying molecular chemistry, particularly those interested in quantum mechanics and covalent bonding phenomena.
meemoe_uk
Hello.
Covalent bonding molicules, right, are usually in lower quantum energy states. e.g. for a typical dihydrogen mol at air temp, the 2 electrons are often in the first or second lowest quantum state.
But, natch, the molicule can still exist with the electron at higher quantum states.
In air, there is a practical limit to how high up the quantum states the electrons can go before the molicule splits.
But how high can the electrons go in theory and still preserve the molicule?
In a very low energy environment, I don't see why high energy electron orbits i.e. the classical orbits, could not be exist and be stable.
If 'classical' covalent bonding is possible under such circumstances, isn't it true that most particles in the universe are subject this long range covalent bonding, it's just the attractive force is so weak as to be negligable?
Molecule.
Only the ground state is stable, everything else will either split the molecule or decay to a lower energy state over time. What can happen where depends on the specific molecule.
No, most atoms don't have electrons in very high orbitals.
  • · Replies 17 ·
  • · Replies 27 ·
