I just got a computer which boots NOT :S
  • Thread starter Thread starter eNathan
    Computer
The discussion revolves around troubleshooting a computer that fails to boot properly. Participants explore potential causes and solutions related to hardware issues, BIOS access, and operating system concerns, with a focus on the technical aspects of diagnosing the problem.
  • eNathan describes the issue of the computer shutting down after displaying a message, theorizing that a virus may be responsible for the failure to boot.
  • Some participants inquire about accessing the BIOS, suggesting that this is a critical step in diagnosing the problem.
  • There are suggestions to boot from a floppy disk or a live CD, such as Knoppix, to bypass the current operating system.
  • Warren points out the need for more information about what happens before the monitor turns off, emphasizing that the diagnosis of a virus lacks evidence.
  • Participants discuss the possibility of various hardware issues, including problems with the video card, power supply, or overheating.
  • There are recommendations to reseat components like the video card, CPU, and RAM to ensure proper connections.
  • Some participants mention the importance of checking for beeping sounds that could indicate specific hardware failures.
  • eNathan shares that the hard drive was connected to a working computer, revealing it likely runs Windows NT and appears to have no personal files, which may indicate a formatted drive.
Participants do not reach a consensus on the cause of the boot failure, with multiple competing theories regarding hardware issues and the role of the operating system. The discussion remains unresolved as participants continue to explore various troubleshooting steps.
Limitations include the lack of specific information about the computer's behavior during boot attempts and the uncertainty regarding the exact nature of the hardware issues. Participants rely on assumptions about the BIOS and hardware functionality without definitive evidence.
eNathan
Hi everyone, I need some help here.
Basically, I have recently received a PC. I do not know what Operating System it runs, although I believe it is either a Win98 or a Win NT. It has an Intel Pentium III processor and has all the hardware with it.
Although I cannot boot it up properly (maybe that is why it was given to me and I didn't pay for it). When I power it up, I get a message from the monitor (NOT from the OS) which says "Off mode in 5 sec" ; 5 seconds later it shuts down.
My theory is that the computer received a virus and the operating system fails to boot. I know that the monitor is not broken because I hooked it up to another PC and it worked fine.
Any help will greatly be appreciated
--eNathan
Computer science news on Phys.org
Can you get into the bios?
Can you boot a floppy? Can you get to the BIOS settings?
Try booting knoppix (http://www.knoppix.org/ ) or some other liveCD... to completely avoid the current OS.
http://forums.thetechguys.com/showthread.php?t=8439 suggests it might be an overheating problem.
http://hardwareanalysis.com/content/topic/19084/ suggests it might be a power-supply problem.
You need to provide more information about what happens before the monitor turns off. (The monitor is going into power-save mode because there is no signal from the computer.) Does the BIOS power-on self-test screen come up? Does it begin booting an OS but then fail? Does anything at all appear on the screen?
There could be a million different hardware problems that would cause the computer to fail this way -- your diagnosis of a virus has little to no evidence.
- Warren
I have no idea how to access the bios, unless I boot it on an MS-DOS OS.
I tried boot disks, they do nothing.
The live Lunix sounds good. I already have one but if I can't find it I will check out knoppix :)
and chroot, when I turned on the computer all it said was "Off mode in 5 sec" -- nothing more nothing less.
Well I hope this Lunix works, thanks for the help everyone :)
When you start the machine you should see something similar to this:
http://www.hardwaves.com/display/2001124/bios_boot.jpg
Note at the bottom of the screen it says press DEL to enter setup. This is how you get into the bios. The bios is software built into the motherboard on a flash memory chip.
If you don't see this type of screen then don't even bother with linux or windows. You won't be able to boot from any media (CD, Floppy, Harddrive)
Do you hear the hard drive spinning up after a while or the cd-rom light flash?
If so: video card is probably dead/not connected fully
If not: bios isn't working and you may want to try to clear it. You'd need the motherboard's manual to find the cmos clear jumper however.
For BIOS, if it's not DEL, it could also be F2.
As Pengwuino implies, it might be a good idea to reseat the video card. Since you're in there, you might as well reseat the CPU and the RAM.
dduardo: I see no screen like that when I boot the linux -- nothing happens :(
Pengwuino: Yes, the CD rom light does come on. How do I know what motherboard I have?
robphy: I was actually pressing F1 because that's the button to enter the BIOS on my computer -- I will try DEL and F2 and see if that works.
How do I reset the video card and RAM? I have opened up the entire computer and see all of its components.
By the way, I also 'unhooked' the broken computer's hard drive and hooked it up to my working computer (which I am using right now). From the looks of it, its a Windows NT. There seem to be NO personal files on the computer, as if the formatted their HD before I received it. Will the fact that I have access to the hard drive files help me also?
eNathan. This has nothing to do with Linux or Windows. Turn on a machine that you do know is working and you should see a screen similar to this:
The bios is the first piece of software that loads into memory and has nothing to do with the operating system your using.
If your not seeing this type of screen I suggest you start pulling out cards from the machine. Everything execpt the video card of course. If need be get a known working video card and put it in the machine.
Pengwuino suggestion to reset the bios is also a good idea.
You can probably read it off the motherboard... but you'll have to look around.
You might get clues from the company and model number on the case.
I wrote reseat... that is, remove from its slot, then reinsert. Do this for the CPU, as well as the video card and the ram.
Yes, it suggests that hard drive failure might not be reason for the problem you have.
Does your computer make any "beeping" sounds? [Check that the internal speaker is properly connected.] Often there are error codes [for example, video card failure] conveyed by specific beeps. http://www.pcguide.com/ts/x/sys/beep/
I'm going to bet that the video card is the problem. I'd remove the video card. Look for any damage. Put it back into its slot. If that fails, try dduardo's suggestion to replace it with a working video card.
(It's possible that there's a short on the motherboard somewhere. Use an air can to clean it up. Look for any stray screws or wires that might lodged in bad places.)
  • · Replies 102 ·
