Find the magnitude of the applied force F
The problem involves determining the magnitude of an applied force F required to push a 115.0 kg box up a frictionless ramp inclined at an angle of 49.0 degrees. The box is moving at a constant speed, suggesting a balance of forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to analyze the forces acting on the box, considering gravitational components in both the x and y directions. Some participants question the relevance of friction, while others clarify that the ramp is frictionless. There is discussion about the correct components of the gravitational force and how they relate to the applied force.
The discussion is ongoing, with participants providing insights into the force components and the relationships between them. Some guidance has been offered regarding the correct approach to resolving the forces, but no consensus has been reached on the final calculations.
The problem is framed within the constraints of a homework assignment, and participants are navigating the assumptions regarding the frictionless nature of the ramp and the forces involved.
ryan
A 115.0 kg box is pushed by a horizontal force F at constant speed up a frictionless ramp which makes an angle of 49.0 deg with the horizontal. Find the magnitude of the applied force F.
I can't seem to get this problem right. In the x-direction there is a push. Which I got mgsin(49).
In the y-direction there is the normal force and mg. mg is negative and I think the normal force is mgcos(49). I'm not positive if this is right but when i add -mg+mgcos(49) and do vector addition on the x and y directions I get the wrong answer. What am i doing wrong?
Hi
What about the frictional force? Don't u have the value of & mu?
Sridhar
the ramp is considered frictionless
Since there are no friction forces you need to do two things:
determine the component of the force in the direction of the incline:
Since the angle of the incline is given as 49 degrees to the horizontal, constructing the right triangle with legs the along the incline and normal to it with hyponetuse horizontal has angle 49 degrees at the bottom and so near side/hypotenuse = cosine. It is correct that the force along the incline would be F cos(49).
I don't know why you would ADD mg and mg cos(49)- that would be adding the total weight to one component. And the WRONG component, by the way: since the weight vector is vertical, not horizontal the component of weight in the direction of the incline is given by the sine: -mg sin(49)= -115(9.81) sin(49)
Of course, we must have F cos(49)= 115(9.81) sin(49). Solve that for F.
  • · Replies 41 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 95 ·
