How to Improve Air Flow in Your PC
The discussion revolves around improving airflow in personal computer (PC) cases, focusing on fan configuration, installation, and maintenance. Participants share their experiences and recommendations regarding the number of fans, the use of filters, and the impact of environmental conditions on dust accumulation.
  • One participant suggests that a PC case should have at least three fans (one intake and two exhaust) for optimal airflow.
  • Another participant recommends installing filters over intake fans to prevent dust accumulation on components.
  • Some participants argue that the necessity of filters depends on individual experiences with dust in their environments, with one noting that filters may be more for noise reduction than dust control.
  • Another participant shares that their older builds accumulated dust quickly, while their newer build requires more frequent filter cleaning.
  • One participant humorously claims to have 15 fans in their system, indicating a preference for extensive cooling solutions, including water cooling.
  • A later reply mentions that if only one fan is used, it should be configured to blow air out for cooling purposes.
Participants express varying opinions on the number of fans needed and the effectiveness of filters, indicating that multiple competing views remain on these topics.
Some participants' claims about dust accumulation and fan effectiveness depend on specific environmental conditions and personal experiences, which may not be universally applicable.
vincentm
Another guide i decided to post here made by moi :)
Your PC case should consist of at least 3 fans( 1 intake, 2 out take) we are going to use my PC as a reference. (pics are crappy so bare with me.)
your front of your case should posses the intake fan this will suck in air to be properly circulated within your case. later to be distribute outwards via the exhaust fans.
Overall direction you want to achieve.
http://img230.exs.cx/img230/2493/picture0196lh.jpg
Above you can see what your going to need to achieve.
as stated earlier your intake should consist of at LEAST 1 fan, I have 2 but you get the idea.
http://img185.exs.cx/img185/259/picture0215yj.jpg
When installing this fan, remove the front panel by way of the 4 screws located behind the face plate itself. this will enable easy install and a hassle free experience. (Do not be in a rush to build your system )
secondly, as stated earlier as well your going to want at least 2 (depending on the size of the case, fulltower cases will let you have 2 outtake fans. Besides the PSU fan, like i have pictured )
http://img177.exs.cx/img177/5225/picture0207cc.jpg
As indicated by the arrows, this is the direction of the air being removed by these fans.( it has to go somewhere it cannot remain in your system, or your components will slowly bake over due time.)
side intake
As an added bonus( mostly depending on the type of rig) it is recommended that you have a side-intake fan.
This is used to provide an additional amount of coolair and help in the overall airflow within your system
(see the pic below)
http://img177.exs.cx/img177/6036/picture0232lm.jpg
the next pic(s) will further show you how your going to want it to be moved throughout your system.
http://img230.exs.cx/img230/6587/picture0252ar.jpg
http://img230.exs.cx/img230/4571/picture180ia.jpg
http://img37.exs.cx/img37/8516/cooling1bm.jpg
Thank you for taking time to review this guide, and hopefully this will help you :)
As always you can post and I, or the helpful folks here will point you in the right direction. Good luck and happy building your killer rig. :)
Computer science news on Phys.org
Filter...
It is also recommended that you install a filter over any intake fans, unless you want your motherboard and daughterboards to become your room's dust filtration system. :smile:
Depends, on how much fans and how well your airflow is. I never had to use a filter nor dust out my system.. once in a blue moon but not regularly. Filter are used more for noise reduction than dust filtration although there are end users that use them for both purposes.
Depends on the condition of the environment. My older builds used to get full of dust bunnies every month or so, and with my latest build, the filter gets pretty clogged every couple of weeks.
3 fans? pff, more like, 15 ;)
Or well, that's how many i got on my system :D. Its water cooled too so i have water blocks where my cpu and gpu fan/heatsink would normally be :D. And 3 fans are the water coolers fans...
Its relatively quiet too :D
One note to add is that if your only running one fan, you want it to blow out air for cooling reasons.
  • · Replies 18 ·
43K
9K
19K
