Are the Paths of Reparameterized Functions Identical?
  • Thread starter Thread starter jessawells
    Functions
The discussion revolves around a problem involving differentiable vector-valued functions, specifically focusing on the reparameterization of a function f by another function g. The original poster expresses uncertainty about how to approach proving the equality of the paths traced by f and its reparameterization h, as well as the relationship between their derivatives.
  • Participants explore the definitions of the functions involved and question the characterization of g as a vector function in a one-dimensional context. There are discussions about the implications of g being onto and its effect on the paths traced by f and h. Some participants suggest using the Chain Rule and consider reparameterization in terms of arclength.
The discussion is ongoing, with participants raising various points and exploring different interpretations of the problem. Some guidance has been offered regarding the use of the Chain Rule, but there is no explicit consensus on the approach to take or the validity of certain assumptions.
There is a noted lack of specific equations for f and g, which some participants feel complicates the problem. Additionally, the original poster mentions an additional piece of information regarding g being onto, which may influence the discussion about the paths traced by the functions.
jessawells
hi,
i was wondering if anyone could tell me how i should approach this problem:
Let f:R->R^3 be a differentiable, vector-valued function and g:R->R be a strictly increasing vector-valued function. Let h = fog:R->R^3. Show that the paths traced by f and h are equal and that h'(t) = f'(g(t))g'(t). h is called the reparameterization of f by g.
i have no idea where to start. I'm not sure how to put the info given in the question to use, to prove that f and h are equal, especially since it doesn't state the equations for f and g. any help is appreciated.
That's not what the problem asks you to prove...
jessawells said:
hi,
I'm not real fresh on this stuff, but it seems odd to me that g is being defined as a "vector function" in a 1-dimensional space, rather than calling it a scaler. In any case, it appears to me that as a starting point in a spatial representation you can write
[tex]\vec f = f_x (x,y,x)\widehat i + f_y (x,y,x)\widehat j + f_z (x,y,x)\widehat k[/tex]
[tex]\vec g = g(t)\widehat u[/tex]
[tex]\vec h (t) = f_x \left[ x \circ g(t),y \circ g(t),x \circ g(t) \right] \widehat i + f_y \left[ x \circ g(t),y \circ g(t),x \circ g(t) \right] \widehat j + f_z \left[ x \circ g(t),y \circ g(t),x \circ g(t) \right] \widehat k[/tex]
or something analogous in another representation in [tex]\Re ^3[/tex].
This doesn't seem to make any sense. Choose g = exp. Then h(R) need not be equal to f(R) so whatever "the path traced" means, I don't think the two can be equal. As for the other part, it's just the Chain Rule. If you only know the Chain Rule for "1-dimensional" functions, you can still use that rule to prove this more general case.
an additional piece of info in the question, which i forgot to type, is:
g is onto - that is, for every y in R, there is an x such that g(x) = y.
anyway, i tried reparameterizing according to arclength. let s1, s2, s3 = arclength of f, g, and h.
functions are f = f(t), and g = g(b).
s1(t) = [integral]|f'(u)| du
ds1/dt = |f'(t)|
s2(b) = [integral]|g'(u)|du
ds2/db = |g'(b)|
s3(b) = [integral]|f'(u)|du
s3/db = |f'(g(b))|
= |f'(g(b))*g'(b)|
i don't know where to go from here. i don't even know if i started off correctly. how do i put all that together to show that the path traced by f = path traced by h? any help would be appreciated.
Perhaps there is some basic property of the function f that is being overlooked. What does f:R->R^3 tell you about the funtion f?
9K
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 38 ·
