| Thread Closed |
mass of water molecule |
Share Thread | Thread Tools |
| Jun9-05, 04:41 PM | #1 |
Is there any way to find the mass of a water molecule when only Avogadro's number is given?
Thanks! - Kamataat |
| Jun9-05, 04:59 PM | #2 |
The mass of one mole of water = 18 grams.
Avogadro's = 6.02x10^23 molecules/mole 18gms/mole divided by 6.02x10^23 molecules/mole should work, if my chemistry isn't too rusty. The mole units will cancel each other, leaving you with units of gms/molecule. Should get something like 3x10^-23 gm/molecule. Actually a little less, since I rounded all numbers off. Please correct me (anyone) if I am incorrect! Good luck. Steve |
| Jun9-05, 06:27 PM | #3 |
Yeah, that's how I'd do it, but I was asking because of the stupid excercise book. It gives all sorts of extra info in the back, in case it's required to solve a problem, but it doesn't give any molar masses. So I thought that maybe there's a clever way to solve this w/o the molar mass.
All I know is Avogadro's number, the definition of a mole (# of atoms in 0.012kg of [itex]C^{12}[/itex]) and Clapeyron's equation. Thanks anyway! - Kamataat |
| Jun9-05, 07:34 PM | #4 |
The easiest way to figure out the molar mass is to look at a pereodic table of elements.....Off the top of my head, two hydrogen(1.01) and one oxygen(16), you just add those and get the molar mass.
Am I missing something....? |
| Jun9-05, 09:36 PM | #5 |
No, that definately should be what you do. Most problems just don't give molar masses for things like water, carbon dioxide, etc. in some chemistry books because the value is given so many times over that it becomes one of those redundant things.
Given only avogadro's number, you definately need to have the molar mass to find the number of molecules. |
| Jun10-05, 02:06 AM | #6 |
The average molar mass for an element is given on any periodic table, and certain isotopes can be looked up. Water is 2 hydrogens (1.01 each) and one oxygen (16) which gives 16 + 2(1.01) = 18.02 g/mol.
[tex] \left(\frac{18.02 g}{1 mol}\right) \left(\frac{1 mol}{6.02 \times 10^{23} molecules}\right) = \left(\frac{ x grams}{ 1 molecule }\right) [/tex] |
| Jun10-05, 08:21 AM | #7 |
Smith basically used this then multiplied by one mole then divided by one mole.
| Jun10-05, 08:40 AM | #8 |
Thanks everyone for making this clear for me!!!
- Kamataat |
| Thread Closed |
| Thread Tools | |
Similar Threads for: mass of water molecule
| Water molecule | Biology, Chemistry & Other Homework | 3 | ||
| degrees of freedom - molecule of water vapor | General Physics | 1 | ||
| Electric Field on a Water Molecule | Introductory Physics Homework | 13 | ||
| Finding angle between hydrogens and oxygen in water molecule | Classical Physics | 7 | ||
| water molecule? | Atomic, Solid State, Comp. Physics | 4 | ||
