Load Resistor in a MOSFET amplifier
The discussion centers on designing a MOSFET amplifier that initially provides a gain of 3.3V/V with a 10K load resistor. Replacing this load with an 8-ohm speaker will significantly reduce the gain due to the impedance mismatch. To maintain performance, it is recommended to implement an additional stage using a source follower configuration, which offers a gain of approximately 1 while driving the 8-ohm load directly from the source without a drain resistor.
  • MOSFET amplifier design principles
  • Understanding of load impedance effects on gain
  • Basic knowledge of source follower configurations
  • Familiarity with AC signal input characteristics
  • Research MOSFET amplifier design techniques
  • Learn about source follower configurations in detail
  • Explore the impact of load impedance on amplifier gain
  • Investigate methods for cascading amplifier stages
Electronics engineers, audio amplifier designers, and hobbyists interested in optimizing MOSFET amplifier performance for various load conditions.
shaiqbashir
Hi Guys!
well! i have designed a mosfet amplifier. This amplifier uses only MOSFET in its operation along with an input signal and capactors and resistors and VDD. I want to ask u one thing.
The amplifier which i have designed takes 0.1V of AC signal as an input and provides a gain of 3.3V/V. it is best for a load of 10K resistor. If i want to connect an 8-Ohm speaker as a load in place of 10K resistor, what modifications do i have to make. Plz help me.
Thanks a lot in advance
The gain depends on the load resistor. If you get a gain of 3.3 with a 10k load resistor, replacing it with a 8Ω resistor will drop dramatically the gain. What you need is another stage. I suggest you use a source follower (gain ~ 1) with the 8Ω charge at the source and no drain resistor.
  • · Replies 28 ·
  • · Replies 31 ·
  • · Replies 29 ·
