How much heat will be generated when a bullet hits a cart?
  • Thread starter Thread starter haki
    Heat Momentum
The discussion focuses on calculating the heat generated when a bullet strikes a cart, specifically a 6.00 g bullet with a kinetic energy (K.E.) of 3.12 J impacting a 122 g cart. Key calculations include determining the bullet's speed before impact (32.2 m/s), the cart's speed after impact (1.5 m/s), and the impulse exerted by the bullet on the cart (0.183 kg m/s). The conversion of kinetic energy to internal energy is also analyzed, revealing that 3.5 J is converted to heat when both the bullet and cart are lead, with a specific heat of 130 J/kg K.
  • Understanding of kinetic energy calculations
  • Familiarity with momentum conservation principles
  • Knowledge of specific heat capacity and heat transfer equations
  • Basic algebra for solving equations
  • Study the principles of momentum conservation in collisions
  • Learn about energy conversion in inelastic collisions
  • Explore specific heat calculations in thermodynamics
  • Investigate the effects of different impact angles on energy transfer
Physics students, engineers, and anyone interested in mechanics and thermodynamics, particularly those analyzing collision dynamics and energy transformations.
haki
Hi.
I have a bit of a dillema and a few problems regarding a simple exercise.
The situation is as folows. We have a 6,00 g bullet that has a K.E. of 3.12 J. It strikes a 122 g cart that is on railway tracks. The bullet hits the cart parallel to the tracks. Now we need to find out 1) Speed of bullet before impact 2) Speed of cart after impact 3) With what impulse did the bullet act on the cart 4) How much K.E of the bullet has converted in the internal energy of the bullet 5) For how much deg. K would the cart and bullet be heated if they are from lead with Specific heat = 130 J /KG K and the heat would not be transimitted to the environment 7) For how much would the cart and bullet be heated if the bullet would hit the cart perpendicular to the railway track.
I have difficulty with 6 and 7 and also a bit with 3.
1) Plain enough. K.E = 1/2 m * v^2 with some basic algebra we find that v = 32,2 m/s
2) Momentum before = Momentum after
m(bullet before)*v(bullet before) + 0(cart has no momentum before) = m(bullet)*v + m(cart)*v
6*32,2 = 6v + 122v with some algebra we find that v = 1.5 m/s[/quote]
Yes, looks good. Since you used grams through out, you don't need to convert to kg.
3) Now the impulse of the bullet on the cart.
Since the momentum of the cart is changed from 0 to m(cart)* 1,5 m/s = 0.183 KG m /s. The change of momentum of the cart is then 0.183 Kg m/s. Then the impulse of the bullet on the cart is equal to the momentum change of the cart = 0.183 Kg m/s. Would my reasoning be correct?
Yes.
4) The K.E(before) = K.E(after) + Internal E.(after)
3.12 J = 1/2 * (6g) * (1.5 m/s)^2 + x would this reasoning be correct? We find that x = 3.11. Total I.E = 3.11 J. Soo we have that 3.11 J of E has converted in the internal energy. Correct?
No. Both cart and bullet are moving at 1.5 m/s. The mass is 6+ 122= 128 g= 0.128 kg. The total kinetic energy after the bullet hits the cart is 1/2*(0.128 kg)(1.5 m/s)2= 0.62 J. That means that 3.12-0.62= 3.5 J was converted to heat.
5) Now with this I am puzzled. I know that E= m * cp(specifci heat) * delta T. But what value should I use for E. I recon. That 3.11 J of Internal goes to heat. Soo we have delta T = 3.11 J / (6g + 122 g) * 130 J/KgK. delta T = 0.18 K. Correct?
The correct E is 3.5 J.
6) For this all of the K.E would go to I.E since neither the bullet nor the cart are moving after the impact. I recon. delta T = 3.12 J / (6g+ 122g) * 130 J/KgK. Delta T = 0.19 K.
Yes.
Everything you have done looks fine except the answer for 5 is 2.5 J not 3.5.
Just one observation: this is one slow bullet. I doubt that a lead bullet traveling at 30 m/sec is going to penetrate a lead block.
AM
Thanks for the reply.
Just one more question: Are you sure that 1/2*(0.128 kg)(1.5 m/s)^2= 0.62 J. I put it in my calc and I got 0.144 J.
Why do we say that the bullet is moving with 1.5 m/s. Isn't the bullet still. It is like a passanger in a bus(cart). Soo no matter what angle of impact, all K.E. of bullet would go in I.E. and bullet would have 0 K.E. from the view point of the cart. The cart would have ofcorse then have 122g*(1,5m/s )^2 of K.E. and the difference between the K.E. of bullet before impact and K.E. of the cart after impact would be the I.E. Soo we have.
K.E.(bullet, before) = K.E.(cart,after) + I.E.(bullet,after), ah...that would not be logical. Since the momentum...I c.
K.E.(bullet, before) = K.E.(cart,after) + K.E.(bullet, after) + I.E.(bullet, after)
we have
3.12 J = 1/2((6 + 122)/1000 kg) * (1.5 m/s)^2 + I.E. we get the solution I.E. = 2.98 J.
Hypothetical situations always make me puzzled.
  • · Replies 24 ·
  • · Replies 29 ·
  • · Replies 31 ·
