Is it Practical to Produce Nitric Acid from Gasoline?
  • Thread starter Thread starter kclo4x
    Acid Gasoline
Producing nitric acid from gasoline is impractical due to the lack of nitrogen-bearing compounds in gasoline. When gasoline is burned, it primarily generates soot, carbon monoxide, carbon dioxide, and nitrogen oxides, but not sufficient amine compounds necessary for nitric acid synthesis. The process would yield dilute nitric acid, but purification to 63% nitric acid through heating is inefficient and not feasible. The discussion highlights the chemical limitations of using gasoline as a precursor for nitric acid production.
  • Understanding of combustion chemistry
  • Knowledge of nitric acid production methods
  • Familiarity with organic compounds and their combustion products
  • Basic principles of gas-phase reactions
  • Research the chemical processes involved in nitric acid production from ammonia
  • Explore the environmental impact of nitrogen oxides from gasoline combustion
  • Investigate alternative methods for synthesizing nitric acid
  • Learn about the purification techniques for nitric acid, including distillation
Chemists, environmental scientists, and anyone interested in the chemical processes of nitric acid production and the implications of gasoline combustion.
kclo4x
Can you burn gasoline to form nox witch can then be condensed with the other impurities to make dilute nitric acid witch could then be purified to make 63% nitric acid (by way of heating till smelling nitric vapors) it would make since that nox could be produced by burning gasoline because it came from organic compounds witch would have amino acids in it witch would burn and create the nox
i know that what happens in automobiles but could it be done and a cup of burning fuel
Chemistry news on Phys.org
What do you need the nitric acid for?
Gasoline does not contain any appreciable amine-or nitrogen bearing compounds. You'll just get soot, formaldehyde, benzene, carbon monoxide, carbon dioxide, water, sulfur dioxide, sulfur tri-oxide (small amount), nitrogen oxides, and a host of much less than 1% of a bunch of other compounds that I am forgetting.
  • · Replies 19 ·
11K
47K
  • · Replies 39 ·
