Finding Moment of Inertia for Rotated Solid: y=sinx, x-axis, [0,pi]
The moment of inertia for a solid formed by rotating the curve of y=sin(x) about the x-axis in the interval [0, pi] can be calculated using the formula for a cylindrical element of mass, dm = ρπy²dx. The moment of inertia for this element is given by I = (1/2)y²dm = (1/2)ρπy⁴dx. By substituting y = sin(x) and integrating over the specified bounds, one can derive the moment of inertia in terms of the total mass M by calculating the volume of revolution V and setting ρ = M/V.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of moment of inertia in physics.
  • Knowledge of solid of revolution and volume calculations.
  • Basic understanding of density and mass relationships in physics.
  • Study the derivation of moment of inertia for various shapes, focusing on solids of revolution.
  • Learn about integration techniques for calculating volumes of solids of revolution.
  • Explore the application of cylindrical shells in calculating moments of inertia.
  • Investigate the relationship between density, mass, and volume in three-dimensional objects.
Students and professionals in physics and engineering, particularly those focusing on mechanics and materials science, will benefit from this discussion on calculating the moment of inertia for solids of revolution.
devious_
How do I find the moment of inertia of a solid formed by rotating the curve of y=sinx about the x-axis in the interval [0, pi]?
I've tried to set up integrals by summing up cylinders parallel to the y-axis but to no avail.
I'm assuming it's the moment of inertia of the solid about the x-axis that the question is asking for.
Let the volume density of the solid of revolution be [itex]\rho[/itex]. Then a cylindrical element of mass [itex]dm[/itex] is defined by [itex]\rho \pi y^2 dx[/itex]. The moment of inertia of that element about the x-axis is defined by [itex]\frac{1}{2}y^2dm = \frac{1}{2}\rho \pi y^4 dx[/itex]. Substitute [itex]y = \sin x[/itex] and integrate over the required bounds and you have the answer. To remove the [itex]\rho[/itex] term and leave your answer purely in terms of the total mass [itex]M[/itex], just calculate the volume of revolution [itex]V[/itex] the usual way and put [itex]\rho = \frac{M}{V}[/itex].
Yeah, that worked!
What I did was EXACTLY the same as your method, except I multipled dm by x^2 instead of y^2. Oops.. :shy:
Thank you. :smile:
  • · Replies 40 ·
  • · Replies 16 ·
