The discussion focuses on the atomic scale properties that influence the hardness of glasses, particularly silicate glasses, in relation to factors such as applied load and loading time. Participants explore concepts like indentation size effect and hardness creep, while considering the microstructural characteristics of glass materials.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant is investigating the hardness variation of glasses and seeks to understand the atomic scale properties that affect hardness, noting a correlation with fictive temperature.
- Another participant suggests that microstructure, including particle distribution and defects, plays a significant role in hardness, especially in micro- or nano-hardness tests.
- It is noted that hardness is correlated with yield strength, and factors affecting yield strength will also influence hardness.
- Discussion includes the complexity of modeling mechanical properties of glasses compared to crystalline solids, with a mention of non-equilibrium behavior like creep.
- One participant emphasizes the importance of microstructural variations and gradients in glass types, as well as the challenges of applying stress measures in brittle materials.
- Hardness creep is described as a logarithmic decay of hardness over time, with a similar decay observed with varying indentation loads, referred to as the indentation size effect.
- Some empirical explanations for hardness behavior, such as Meyer's Law, are mentioned, but participants express that not much research has been done on these phenomena.
- One participant shares a theory that hardness creep may be related to hydroxyl adsorption, noting that this effect is not observed in nonaqueous liquids.
- References and articles related to hardness creep and indentation size effect are offered for further exploration.
Participants generally agree on the significance of microstructural factors in influencing hardness but express uncertainty regarding the specific atomic scale properties and the mechanisms behind hardness creep. Multiple competing views and theories are presented without a consensus on the underlying causes.
The discussion highlights limitations in understanding the mechanistic explanations for hardness behavior in glasses, particularly regarding the influence of environmental factors like water on yield strength and time-dependency in hardness.
