Vector Dynamics on an Inclined Plane
The discussion revolves around a physics problem involving vector dynamics on an inclined plane, specifically focusing on the forces acting on two blocks, one of which is moving up the incline while the other is descending. The original poster attempts to analyze the forces involved, particularly the applied and opposing forces.
  • Participants explore the net forces acting on each block, questioning the assumptions about the forces of gravity, tension, and friction. There is discussion about the implications of a zero net force in the context of the system's motion.
The discussion is active, with participants engaging in clarifying the forces at play and questioning the original poster's assumptions. Some guidance has been offered regarding the need for force diagrams and the relationship between the forces acting on the blocks.
There is an indication of confusion regarding the roles of different forces, particularly in relation to the motion of the blocks and the conditions of equilibrium. The original poster's reference to a test question suggests constraints on the information available for analysis.
seiferseph
http://i2.photobucket.com/albums/y15/seiferseph/untitled.jpg
recently had this question on a test, we're told the left block moves up the incline at a constant rate. here's what i did
Fnet = Fappl - Fopp
Fnet = 0 because no acceleration
Fopp = Fappl
the applied force would only be the weight of the right one, and the opposing force would only be friction on the incline?
does the force weight of A (Fw for a times sin theta) also oppose the motion?
The net force on WHAT is zero? Do a force diagram for each block. The one on the right has a force of gravity pulling down and a force of tension pulling up, however it is sitll descending, which tells you something.
that is taking the system, since there is no accel the fnet if the system is zero, and the applied force is the weight of the hanging one. i was wondering what the opposing forces would be.
The right block (descending) has an et force of zero, which means the force of gravity pulling down equals the force of tension, pulling up. What's causing the force of tension? The other block, so what's the force on the other block...
just got it, thanks!
  • · Replies 36 ·
  • · Replies 19 ·
