Equilibrium & Weightlessness: Mechanics Questions
  • Thread starter Thread starter briton
    Mechanics
The discussion revolves around concepts of equilibrium and weightlessness in mechanics, particularly in the context of a ball thrown into the air and the conditions experienced by astronauts in orbit.
  • Participants explore whether a ball at rest at the peak of its trajectory is in equilibrium, questioning the role of gravitational force. They also discuss the definition of weightlessness, considering scenarios like free fall and orbital motion.
The discussion is active, with participants offering differing viewpoints on equilibrium and weightlessness. Some clarify definitions and conditions, while others raise questions about the implications of forces acting on objects in various states of motion.
Participants are navigating the nuances of equilibrium conditions and the specific definitions of weight and weightlessness, indicating a need for clarity on these concepts. There is an acknowledgment of the technical meanings of terms used in physics.
briton
If a ball is thrown in the air and comes momentarily at rest is it at equilibrium?
I thought yes because it's stationary, but then again.. there is a resultant gravitational force.. ?
Also what is "weightlessness" exactly?
Is it when you're in freefall/only gravity acts? so that would be like an astronaut in a satellite orbiting the earth?
Equilibrium conditions are:
[tex]\sum F = 0, \sum \tau = 0[/tex] where [itex]\tau [/tex] is the torque. <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Also what is "weightlessness" exactly? <br /> Is it when you're in freefall/only gravity acts? so that would be like an astronaut in a satellite orbiting the earth? </div> </div> </blockquote><br /> I want to say you feel weightless when your body feels no net force, but there is a net centripetal force during orbit.[/itex]
When the ball is at rest at the top , it is being acted upon by the 'g' downwards , so it is not in equilibrium .
Weightlessness is 'free fall under gravity ' This is when your weight downwards (mg) is balanced by pseudo force uppwards when you are freely falling ...
Example: You are in a lift and the rope breaks and then you fall freely , you will lose contact with ground and you are under free fall.
For more:
http://science.howstuffworks.com/weightlessness.htm
Yes. "Weightlessness" is when your apparent weight is zero. Your apparent weight, the "weight" that you feel, is due to the normal force of whatever surface is holding you up (or other force preventing you from falling). Take away the support, and you feel "weightless". (In physics, the term weight has a specific technical meaning: the force of gravity on an object. So, while you may experience the feeling of "weightlessness", your real weight is not zero!)
  • · Replies 40 ·
9K
  • · Replies 24 ·
  • · Replies 39 ·
