Calculating Rate of Change in Graphs: Is it Just Gradient?
The discussion revolves around calculating the rate of change in graphs, specifically whether it is equivalent to the gradient. Participants explore the concept of rate of change in the context of derivatives and slopes in various types of graphs.
  • Conceptual clarification, Mathematical reasoning
  • Some participants attempt to define "rate of change" in terms of derivatives and gradients, while others question the clarity of the original poster's terminology. There is also a discussion about the differences in terminology between regions, such as "gradient" versus "slope."
The conversation is ongoing, with participants providing insights into the definitions and interpretations of rate of change and gradient. Some guidance has been offered regarding the relationship between derivatives and gradients, but there is no explicit consensus on the terminology used.
There is mention of potential confusion due to the original poster's phrasing and the cultural differences in mathematical terminology. The discussion reflects varying levels of familiarity with the concepts involved.
flo123
how do you calculate the rate of change in a graph?? is it just the gradient??
Since your "rate of change" sounds terribly vague,i'll assume that it means "the change in <<y>> corresponding to an infinitesimal change in <<x>>",which means the derivative of the function at a specific point.
Daniel.
Daniel.
Usually a premise, whether assumed or not, is followed by a conclusion. You didn't address his question :smile:
The rate of change at a point on a graph is the slope or gradient at that given point. For linear graphs of form [itex]y = mx + b[/itex] the gradient is constant throughout the graph, for others calculus is used to find the rate of change.
Yes, he did when he said "which means the derivative of the function at a specific point." "Derivative" is what us Yanks call the "gradient".
In that case, its a run-on sentence :biggrin:, and that's why it doesn't make immediate sense.
I was taught math in the US and I've only heard gradient when it comes to vector fields. This is the only place I've heard gradient used instead of slope or derivative.
Thanks for the replies, sorry it has caused tension in this debate about my vague question, the derivative of an equation is the gradient simple really... and its a her not a he
plus what other answers other than the change in y and x, could there be on a graph??
  • · Replies 19 ·
