General relativity and quantam - what would happen?
This discussion addresses the implications of special relativity and quantum mechanics on mass and perception at high speeds. It clarifies that while a person on a high-speed circular ride may perceive a longer circumference due to relativistic effects, an outside observer would not see the ride as smaller. The mass of the ride remains constant regardless of speed, contradicting the notion that it could achieve immense mass. Additionally, the wave-particle duality of mass, supported by experiments like the double slit experiment, remains a fundamental principle in quantum mechanics.
  • Understanding of special relativity principles
  • Familiarity with quantum mechanics concepts
  • Knowledge of the double slit experiment
  • Basic grasp of wave-particle duality
  • Research the implications of special relativity on mass and length contraction
  • Explore the double slit experiment and its significance in quantum mechanics
  • Study the concept of wave-particle duality in depth
  • Investigate the effects of high-speed motion on perception and measurement
Physicists, students of physics, and anyone interested in the interplay between relativity and quantum mechanics.
dre
Here are my two questions:
1. At higher speeds objects appear smaller. Fine. Now if a person is in a tornado ride (the circular ride where it spins around and makes you stick to the wall) and the machine is going at sufficient speed, he will measure a longer circumference since his ruler will appear shorter.
My question is this: wouldn't the entire circular ride appear smaller to an outside observer? Thus cancelling out his shorter ruler? And if the thing kept spinning, would it keep getting smaller and smaller and achieve an immense mass?
2. Mass is both wave and particle. The double slit experiment. Great. But is it possible that mass is not both wave and particle, rather particles traveling along rippled time-space? Small ripples due to objects surrounding the particle, ripples due to the earth, and even ripples due to the particle itself.
1. In the scenario described, the person inside the tornado ride would indeed measure a longer circumference due to the effects of special relativity. However, an outside observer would not necessarily see the ride as smaller. This is because the effects of special relativity depend on the relative speeds and perspectives of the observer and the observed object. So while the person inside the ride may see a longer circumference, an outside observer may not see any significant change. As for the ride achieving immense mass, this would not happen as the mass of an object does not change with its speed. The mass of the ride would remain the same regardless of its speed.
2. The concept of mass as both a wave and a particle is based on the principles of quantum mechanics and has been supported by various experiments, including the double slit experiment. While it is possible that there could be ripples in space-time due to surrounding objects, it does not necessarily mean that mass is traveling along these ripples. The wave-particle duality of mass is a fundamental principle in quantum mechanics and has been well-tested and verified through experiments. While there may be other factors at play, the evidence for mass being both a wave and a particle is strong.
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 50 ·
  • · Replies 67 ·
  • · Replies 21 ·
