Application of partial derivatives
The discussion focuses on the application of partial derivatives to determine the angle theta between a sloping plane ceiling and a horizontal floor using an equilateral triangle. The solution provided demonstrates that partial derivatives are unnecessary for this problem. Instead, the angle is derived using the coordinates of the triangle's vertices and the equation of the ceiling plane, leading to the formula: tan^2(theta) = 4(a^2 + b^2 + c^2 - ab - bc - ac)/3t^2.
  • Understanding of trigonometric identities, specifically tan^2(theta) = sec^2(theta) - 1.
  • Familiarity with vector and scalar products in three-dimensional geometry.
  • Knowledge of the geometric properties of equilateral triangles.
  • Ability to derive equations of planes in three-dimensional space.
  • Study the derivation of the equation of a plane given three points in three-dimensional space.
  • Learn about the geometric interpretation of angles between planes in 3D geometry.
  • Explore advanced applications of trigonometric identities in solving geometric problems.
  • Investigate the use of partial derivatives in optimization problems within calculus.
Students and professionals in mathematics, physics, and engineering who are interested in geometric problem-solving and the application of trigonometry in three-dimensional contexts.
WY
Hey,
I have no idea where to start, for this question. I know that I will probably have to use vector and scalar product and use the trig identity tan^2(theta)=sec^2(theta)-1 - and of course partial derivatives
Question:
In order to determine the angle theta which a sloping plane ceiling makes with the horizontal floor, an equilateral traingle of side-length l is drawn on the floor and the height of the ceiling above the three vertices is measured to be a,b and c. Show that:
tan^2(theta) = 4(a^2 + b^2 + c^2 - ab -bc - ac)/3t^2
Thanks in advance for anyone's help!
WY said:
Hey,
Question:
WY, I've seen your post elsewhere. Others may be like me: I don't know. However, if it were my problem and I HAD to solve it, I tell you what, you can be sure I'd be making a nice size cardboard, wood, plastic whatever sloping ceiling, nothing big, few feet maybe, draw my triangle on the floor, measure the distances and just start working with it. It's an interesting problem and I think, if no one helps you, that's a good place to start. :smile:
Solution
There is no need of partial derivatives. Here is the solution:
Consider the floor to be the x-y plane and the 3 vertices of the equilateral triangle A(0,0,0), B(t,0,0), C(t/2,(sq. root of 3)t/2,0).
The points in the plane of the ceiling will be
P(0,0,a), Q(t,0,b), R(t/2,(sq. root of 3)t/2,c)
The eqn of the plane of ceiling through these points (after simplificaton) is obtained as
(sq root 3)(a-b)x+(a+b-2c)y+(sq root 3)t(z-a) = 0
Eqn of x-y plane is z = 0
The angle theta between these planes is obtained as
cos(theta) = (sq root 3)t/(sq root of (3(a-b)^2+(a+b-2c)^2+3t^2) )
Using tan^2(theta) = sec^2(theta)-1 and symplifying we get
tan^2(theta) = 4(a^2+b^2+c^2-ab-bc-ca)/3t^2
