Conduction and displacement current density
The discussion focuses on calculating the ratio of conduction current density to displacement current density in copper for an electric field described by E = E_0 cos(ωt) at a frequency of 1 kHz. The displacement current density is calculated as J_d = -ε_0 E_0 sin(ωt)ω, where ε_Cu = ε_0 and ω = 2πf. The conduction current density is derived using Ohm's law, J = σE = (1/ρ)E, confirming that both currents oscillate in phase under these conditions.
  • Understanding of electric fields and their time dependence
  • Knowledge of displacement current density and its calculation
  • Familiarity with Ohm's law and conductivity
  • Basic principles of electromagnetism, including Maxwell's equations
  • Study the derivation and implications of Maxwell's equations in electromagnetic theory
  • Learn about the physical significance of displacement current density in various materials
  • Explore the relationship between frequency and conductivity in conductive materials
  • Investigate the effects of frequency on the behavior of electric fields in conductive media
Electrical engineers, physicists, and students studying electromagnetism, particularly those interested in the behavior of electric fields in conductive materials.
tiagobt
Could anyone help me solve the following problem?
Calculate the ratio of the conduction current density to the displacement current density of the electric field [itex]E = E_0 \cos(\omega t)[/itex] in copper, to a frequence of [itex]f = 1 kHz[/itex]. (Given: [itex]\epsilon_{Cu} = \epsilon_0[/itex], [itex]\rho_{Cu} = 2 \times 10^{-8} \Omega m[/itex]).​
First, I calculated the displacement current density:
[tex]J_d = \epsilon_{Cu} \frac {dE} {dt} = - \epsilon_0 E_0 \sin(\omega t)\omega[/tex]
I'm not sure if it's correct. Besides, I don't know how to find the conduction current density. I thought about using:
[tex]\vec{\nabla} \times \vec{B} = \mu_0 (\vec{J} + \epsilon_0 \vec{J_d})[/tex]
But is there a magnetic field? I'm confused...
A frequency of 1 kHz is pretty small for this situation. So, for the conduction current density, I think you can just use Ohm's law: ##J = \sigma E = \frac{1}{\rho} E = \frac{1}{\rho} E_0 \cos(\omega t) ##. In this case, the conduction current and the electric field oscillate in phase.
