Angular Acceleration Problem/ Solid Cylinder
The discussion focuses on calculating the angular acceleration of a solid cylinder with mass M = 1.14 kg and radius R = 6.3 cm, subjected to a downward force F = 4.606 N. The angular acceleration without an attached block is determined to be 3.64 rad/s². When a block of mass m = 0.47 kg is attached, the angular acceleration changes to 2.99 rad/s² due to the increased moment of inertia. Additionally, the distance traveled by the block between t = 0.51 s and t = 0.71 s is calculated to be 0.028 m.
  • Understanding of angular acceleration and torque
  • Familiarity with the moment of inertia for solid cylinders
  • Knowledge of basic kinematic equations
  • Ability to perform unit conversions (e.g., cm to m)
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the relationship between linear and angular motion
  • Explore the effects of friction on angular acceleration
  • Investigate the dynamics of systems with multiple connected bodies
Students and professionals in physics, mechanical engineering, and anyone interested in understanding rotational dynamics and the behavior of solid bodies under applied forces.
melissa_y
1) A solid cylinder of mass M = 1.14 kg and radius R = 6.3 cm pivots on a thin, fixed, frictionless bearing (see Figure). A string wrapped around the cylinder pulls downward with a force F = 4.606 N. What is the magnitude of the angular acceleration of the cylinder? Use units of "rad/s\^{}2".
2)Consider that instead of the force F, a block with mass m = 0.47 kg (with force F = 4.606 N) is attached to the cylinder with a massless string (see Figure). What is now the magnitude of the angular acceleration of the cylinder? Use units of "rad/s\^{}2".
3) How far does mass m travel downward between t = 0.51 s and t = 0.71 s (Assuming motion begins at time t = 0.0 s)?
Use units of "m".Answer:1) The magnitude of the angular acceleration of the cylinder is 0.50 rad/s^2.2) The magnitude of the angular acceleration of the cylinder is 0.76 rad/s^2.3) The mass m travels a distance of 0.20 m downward between t = 0.51 s and t = 0.71 s.
1) To solve this problem, we can use the formula for angular acceleration: α = τ/I, where α is the angular acceleration, τ is the torque, and I is the moment of inertia. In this case, the torque is caused by the force F pulling downward on the string, and the moment of inertia for a solid cylinder is given by I = 1/2MR^2. Plugging in the values, we get:
α = (4.606 N * 6.3 cm)/ (1/2 * 1.14 kg * (6.3 cm)^2)
= 3.64 rad/s^2
Therefore, the magnitude of the angular acceleration of the cylinder is 3.64 rad/s^2.
2) In this case, the block attached to the cylinder adds to the total mass and changes the moment of inertia. The new moment of inertia is given by I = 1/2(M + m)R^2. Plugging in the values, we get:
α = (4.606 N * 6.3 cm)/ (1/2 * (1.14 kg + 0.47 kg) * (6.3 cm)^2)
= 2.99 rad/s^2
Therefore, the magnitude of the angular acceleration of the cylinder is 2.99 rad/s^2.
3) To find the distance traveled by the block, we can use the formula for displacement: s = ut + 1/2at^2, where s is the displacement, u is the initial velocity (which is zero in this case), a is the acceleration (which we can find using the formula α = F/mR), and t is the time interval.
s = 0 + 1/2 * (4.606 N/0.47 kg * 6.3 cm) * (0.71 s)^2 - 1/2 * (4.606 N/0.47 kg * 6.3 cm) * (0.51 s)^2
= 0.028 m
Therefore, the block travels a distance of 0.028 m between t = 0.51 s and t = 0.71 s.
  • · Replies 21 ·
  • · Replies 17 ·
