Lightly Damped Harmonic Oscillator
The total mechanical energy of a lightly damped harmonic oscillator is expressed as E = E_0 e^{-bt/m}, where E_0 represents the initial energy at t = 0. The fractional energy lost per period is calculated as \frac{\Delta E}{E} = \frac{2 \pi b}{m \omega_0} = \frac{2 \pi}{Q}, with \omega_0 defined as \sqrt{k/m} and Q as the quality factor, Q = m \omega_0 / b. A higher Q value indicates that the oscillator can sustain oscillations longer with minimal energy loss.
  • Understanding of harmonic oscillators and their equations of motion.
  • Familiarity with the concepts of damping and quality factor (Q).
  • Basic calculus for deriving energy loss equations.
  • Knowledge of potential and kinetic energy in mechanical systems.
  • Study the derivation of the equations for damped harmonic motion.
  • Learn about the implications of the quality factor (Q) in oscillatory systems.
  • Explore energy conservation principles in mechanical systems.
  • Investigate the effects of different damping coefficients on oscillation behavior.
Students and professionals in physics, mechanical engineering, and applied mathematics who are studying oscillatory systems and energy dynamics in lightly damped harmonic oscillators.
e(ho0n3
Question:
(a) Show that the total mechanical energy of a lightly damped harmonic oscillator is
[tex]E = E_0 e^{-bt/m}[/tex]
where [itex]E_0[/itex] is the total mechanical energy at t = 0.
(b) Show that the fractional energy lost per period is
[tex]\frac{\Delta E}{E} = \frac{2 \pi b}{m \omega_0} = \frac{2 \pi}{Q}[/tex]
where [itex]\omega_0 = \sqrt{k/m}[/itex] and [itex]Q = m \omega_0 / b[/itex] is called the quality factor or Q value of the system. A larger Q value means the system can undergo oscillations for a longer time.
My Answer:
(a) When the velocity of the oscillator is 0, the total mechanical energy is purely potential energy, [itex]U = 1/2kx^2[/itex]. Since I know that [itex]x = Ae^{-bt/(2m)}\cos{\omega't}[/itex] where t is some multiple of [itex]2\pi/\omega'[/itex], then
[tex]E = \frac{1}{2}kA^2e^{-bt/m}[/tex]
and [itex]E_0 = 1/2kA^2[/itex]. Of course, this is only valid when the velocity of the oscillator is 0, but since it is lightly damped the total mechanical energy should be approximately the same when the velocity is > 0. Right?
(b) Using some calculus, I can timidly state that
[tex]\frac{\Delta E}{\Delta t} \approx \frac{dE}{dt} = -\frac{E_0b}{m}e^{bt/m}[/tex]
and since [itex]\Delta t = 2\pi / \omega'[/itex] then
[tex]\frac{\Delta E}{E} = -\frac{b\Delta t}{m} = -\frac{2\pi b}{m\omega'}[/tex]
Since the oscillator is lightly damped, [itex]\omega' \approx \omega_0[/itex]. However the result I get is negative. Should it be negative?
Yes, it should be negative because you calculated the rate of change of energy, which is decreasing with time. The question asked for the fractional energy loss, which is the absolute value of the energy change.
Your calculation of the times at which the energy is all potential is overlooking the fact that the peaks in x do not correspond to the points where the cosine has value 1 because the exponential is also time dependent. However, the times between peaks still satisfy the condition you used, so the result follows subject to the other approximations you made.
(c) To find the fractional energy lost per period, we can use the formula
\frac{\Delta E}{E} = \frac{E-E_0}{E_0} = \frac{E_0 e^{-bt/m}-E_0}{E_0} = e^{-bt/m} - 1
Using the fact that \omega' = \omega_0 and \omega' = \omega_0 - \frac{b}{2m}, we can rewrite this as
\frac{\Delta E}{E} = e^{-2\pi b/m\omega_0} - 1 = \frac{2\pi b}{m\omega_0} - 1
Since \omega_0 = \sqrt{k/m} and Q = m\omega_0/b, we can rearrange to get
\frac{\Delta E}{E} = \frac{2\pi b}{m\omega_0} - 1 = \frac{2\pi}{Q} - 1
So, the fractional energy lost per period is indeed \frac{2\pi}{Q}. This means that a larger Q value results in a smaller fractional energy lost per period, indicating that the system can undergo oscillations for a longer time without losing a significant amount of energy.
