How does the line integral method solve ODEs?
  • Context: Graduate
  • Thread starter Thread starter saltydog
    Ode Perspective
The discussion revolves around the method of line integrals in solving ordinary differential equations (ODEs), specifically focusing on the interpretation and implications of integrating functions defined by ODEs. Participants explore the relationship between line integrals, projections onto surfaces, and the solutions of ODEs.
  • One participant introduces the concept of using line integrals to solve ODEs, suggesting that finding a curve in the x-y plane corresponds to solving the equation.
  • Another participant corrects their earlier interpretation of the integral equation, clarifying that the integration should be from specific limits rather than along the curve itself.
  • A participant proposes a new concept called "projection integral," describing a method to project a trajectory onto a flat surface and integrate it to find solutions to ODEs.
  • Discussion includes a specific example of the ODE \(\frac{dy}{dx}=y\) and its solution \(y(x)=e^x\), noting the relationship between the integral equation and the projection of the solution path.
  • Concerns are raised about the rigor of limits of integration and the need for careful handling of these limits in the context of the discussion.
  • Another participant expresses interest in the uniqueness of solutions to ODEs, particularly in cases where conditions are not met, leading to multiple solutions.
Participants exhibit a mix of agreement on the general approach of using line integrals while also expressing uncertainty and disagreement regarding the specifics of integration limits and the implications of their proposed methods. The discussion remains unresolved on several technical points.
Limitations include potential misunderstandings of integration limits, the need for rigorous definitions of projection functions, and the implications of non-uniqueness in solutions to ODEs. Some participants acknowledge the complexity of these issues without reaching a consensus.
This discussion may be of interest to those studying ordinary differential equations, particularly in exploring alternative methods of solution and the geometric interpretations of integrals in the context of ODEs.
saltydog
Though you guys might find this interesting. It's something I've not seen before. Consider the ODE:
[tex]\frac{dy}{dx}=f(x,y)[/tex]
and the attached plot below.
The blue represents the surface for the function f(x,y) (some particular example for the plot) in the first quadrant.
The vertical lines represents the line integral along the curve y(x) that is a (particular) solution for the ODE.
That is, we can say:
[tex]y(x)=y_0+\int_{y(x)} f(u,v) ds[/tex]
And thus solving the differential equation amounts to finding a curve in the x-y plane such that the value of the line integral starting from the point [itex](x_0,y_0)[/itex], along the curve y(x), to the point (x,y(x)), plus [itex]y_0[/itex] is the same as the value of y(x).
Why do I find that amazing?
For the record I was in error above.
[tex]y(x) \ne y_0+\int_{y(x)} f(u,v) ds[/tex]
but rather simply:
[tex]y(x)=y_0+\int_a^b f(t,y(t)) dt[/tex]
Thank God I'm not a Mathematician and I apologize if anyone was led astray by this.
I believe I've resolved my mis-interpretation of the integral equation derived from the first order ODE:
Upon integration of both sides, we obtain:
[tex]y(x)=y_0+\int_{x_0}^x f(t,y(t))dt[/tex]
Erroneously above, I interpreted this to mean integration around the path that is y(x) when actually, I'm beginning to realize it's more like integration of the projection of the line integral onto a flat surface behind the x-y-plane. I hereby cristen this operation a "projection integral" and wish to define it in general:
Take any continuous function f(x,y) in the first quadrant and mark a trajectory upon it's surface that is one-to-one from the points [itex](x_0,y_0,z_0)[/itex] to [itex](x_1,y_1,z_1)[/itex]. Project the resulting curve onto a flat surface orthogonal to the x-y plane (and behind it). Integrate this curve from [itex]x_0[/itex] to [itex]x_1[/itex]. The resulting integral is:
[tex]\int_{x_0}^{x_1} P(t) dt[/tex]
where P is the projection function. Now, if the trajectory so marked on f(x,y), results from a path taken along the x-y plane in terms of some function g(x) which satisfies the following equation:
[tex]g(x)=y_0+\int_{x_0}^x P(t)dt[/tex]
Then g(x) satisfies the differential equation:
[tex]\frac{dg}{dt}=f(x,y)[/tex]
I believe this is correct and will pursue verifying it.
Consider the equation:
[tex]\frac{dy}{dx}=y;\quad y(0)=1[/tex]
Solving we obtain:
[tex]y(x)=e^x[/tex]
We know that this function satisfies the integral equation:
[tex]y(x)=1+\int_0^x y(t)dt[/tex]
The first plot shows the equation f(x,y)=y in blue. Underneath this plot, shown in vertical lines, is the path that the solution [itex]y(x)=e^x[/itex] takes connecting it with the points immediately above it on the surface f(x,y). I was incorrect above to suggest that the corresponding line-integral along this path was directly related to the integral or differential equation. However, it's becomming clear to me that it's projection to a wall orthogonal to the x-y plane is related. The second plot is the projection of those lines to such a wall. They form a function I call C(x). The thick line is the curve [itex]y(x)=e^x[/tex] which fit it nicely. [itex]y(x)=e^x[/itex] of course is the solution to the differential equation.<br /> <br /> What I find interesting is that this is the case for more complicated expressions for the function f(x,y). In fact, I suggest our goal of solving an ODE is to determine the projection function C(x) such that:<br /> <br /> [tex]g(x)=y_0+\int_{x_0}^x C(t)dt[/tex]<br /> <br /> where g(x) satisfies the differential equation. I know this may be obvious but I still find it interesting to look at the solution of an ODE from this perspective. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" /><br /> <br /> <br /> Edit:Oh yea, I suspect an analogous interpretation can be made for higher-ordered ODEs. That is, is there and if so, what is the projection function for a second-order ODE? Is it a surface, the volume underneath of which as a function of x and y, satisfy the differential equation?[/itex]
Just a general comment.
You are on a pretty good track, of course a good fundamental course in ODE's would cover much of what you are playing with.
Hint: You are being very caviler with your limits of integration, take better care of them, understand what they mean in terms of your integral.
Hopefully Halls of Ivy will drop in and add his $.02.
Hello Integral. Yes, a fundamental course. I don't believe I had that with Rainville and Bedient. And Devaney's book, which I've used a lot, is mostly qualitative. Might you kindly tell me specifically where I'm not being rigorous with the limits of integration? :smile:
Suppose I need to make another correction: g(x) above satisfies the differential equation only if:
[tex]P(t)=f(t,g(t))[/tex]
with:
[tex]\frac{dg}{dx}=f(x,g)[/tex]
Suppose that's kind of a circular argument. The geometry is still interesting though. Take for example:
[tex]\frac{dy}{dx}=\frac{1}{y};\quad y(0)=0[/tex]
Ignoring for the moment the Lipschitz condition is not met and we obtain two solutions, consider for the moment the positive solution:
The first plot shows [itex]f(x,y)=\frac{1}{y}[/itex] in blue along with the path of the solution underneath it.
The second plot is the solution.
The third plot is the projection function C(t) with y(x) described in terms of this function as:
[tex]y(x)=y_0+\int_{x_0}^x C(t)dt[/tex]
I looked up the references you gave the first appears to be a first "how to solve" course the second appears to an applications course. By fundamental I meant a ODE theory course I took mine from Ordinary Differential Equations in Rn by Piccinini,Stampacchia, & Vidossich. This book starts from page 1 with constructions similar to your approach. Essentially each solution to a ODE is one of a family of "curves". The "curve" followed is defined by the initial conditions.
I may have been off the mark in my initial assement. Let me spend some more time looking at what you are doing.
You know Integral, I'm really interested in uniqueness and what determines the number of solutions at a point which fails the Lipschitz condition: some ODEs have 2 solutions, some 3, some an infinite number. But I understand you're retiring so that's ok if I don't here from you. Look at the bright side: You could be going to Louisiana. It's in the mid-90's now. The gumbo's good though.:-p
  • · Replies 16 ·
  • · Replies 65 ·
10K
