Protein Synthesis: mRNA Codon, tRNA Anticodon & DNA Codon
  • Thread starter Thread starter student007
    Protein Synthesis
The discussion revolves around the processes of transcription and translation in protein synthesis, specifically focusing on the relationships between mRNA codons, tRNA anticodons, and DNA codons. Participants explore the complementary nature of these sequences and the implications for amino acid coding, including the concept of "wobble" pairing and the effects of mutations.
  • Some participants assert that mRNA is complementary to the anti-sense (non-coding) strand of DNA, while others suggest it is the same as the sense strand, leading to confusion about the relationship between codons.
  • There is a discussion about the presence of uracil in RNA versus thymine in DNA, with examples provided to illustrate the differences in codon sequences.
  • Participants introduce the concept of "wobble" pairing, explaining how a single tRNA can bind to multiple codons due to its three-dimensional structure.
  • Some participants mention that the genetic code is degenerate, allowing for silent mutations where changes in mRNA codons do not affect the resulting amino acid.
  • There is a debate about the implications of mutations in genes and tRNA, with some arguing that certain mutations can be compensated for by corresponding changes in tRNA, while others emphasize that any mutation alters the amino acid sequence.
  • One participant notes that mutations can sometimes be corrected by changes in tRNA, allowing the correct amino acid to be incorporated despite genetic changes.
Participants express differing views on the relationship between DNA, mRNA, and tRNA sequences, particularly regarding the nature of transcription and the implications of mutations. The discussion remains unresolved with multiple competing perspectives on these topics.
Limitations include potential misunderstandings about the definitions of sense and anti-sense strands, as well as the complexities of mutation effects on protein synthesis. The discussion does not resolve these ambiguities.
student007
In transcription, the mRNA, with the help of RNA polymerase, creates a code complementary to the sense strand on the DNA (i think). So does that mean that the mRNA's codon is opposite of the actual codon that codes for a protein? This would mean that the anticodon on the tRNA and the codon on the initial DNA would be the same. So, for example, for the amino acid methiomine, would the codon "sequence" be AUG (which is on the mRNA), or UAC (which is on the DNA and tRNA)?
Biology news on Phys.org
Some correction. During transcription, RNA polymerase creates mRNA that is complementatry to anti-sense (the non coding strand) DNA strand. So the mRNA is the same as the sense DNA strand.
Yes you are right in term of your logic.
Nay
NO. DNA does not contain the base Uracil. It contains Thymine instead. So it would be:
Original DNA: TAC
mRNA Strand: AUG
tRNA Strand: UAC
DNA would not be the exact same as tRNA. It would be the same except for the Thymine/Uracil difference.
DNA is not the same as mRNA. mRNA is complimentary to DNA, that is correct. But it will have a Uracil anywhere there was a Thymine in the DNA that the mRNA was coded from.
Original DNA: TAC
mRNA Strand: AUG
tRNA Strand: UAC
i think that when he said "the same" iansmith already assumed the U/T difference.
The tRNA gets a little more interesting because its tertiary (3 dimensional structure) allows a tRNA charged with an amino acid (tRNA-aa) to bind to more than one codon on the mRNA because of a thing called "wobble" pairing. This position corresponds to the 3rd codon position on the mRNA (5' to 3') and the 1st position of the tRNA (5' to 3'). This means that a single charged tRNA can bind to more than one codon.
3' UAC 5'
5' AUG 3'
Was clarifying, since he said "UAC (which is on the DNA" made me wonder if he knew.
3' UAC 5'
5' AUG 3'
yes, and this is why the genetic code is said to be degenerate.
it is also interesting that single mutations in a gene can be overshadowed by mutations in a corresponding tRNA to set everything back again!
Or you don't even need a mutation in a corresponding tRNA. I can't think of an example off the top of my head, but if you have a silent point mutation in mRNA, some codons code for the same amino acid. There's about 60 codons and 20 amino acids I believe. So you have doubles, even triples.
EDIT: Just did a google search, and here's an example:
UUU (Phe/F)Phenylalanine
UUC (Phe/F)Phenylalanine
Both code for Phe, so if you had a UUU have a silent mutation to UUC, it wouldn't matter.
Source: http://en.wikipedia.org/wiki/Genetic_code
you misunderstand me. there are single mutations that would matter.
let's say that you have a mutation in a gene that winds up substituting Ser instead of Leu(TTG->TCG). it has been observed that frequently this will be accompanied by a mutation in the sequence of DNA that makes the tRNA for Leu to match the new mutated anticodon for Ser, thus undoing the mutation.
Oh I see what you are saying. But then it's still technically a mutation, and it screws up the amino acid sequence, because you have a different amino acid than originally intended, hence, a different protein.
no, there isn't since the mutation in the tRNA will exactly undo the mutation in the gene.
however, you are right in that it is still a mutation since the genetic sequence has been changed - but not the amino acid sequence.
You said previously that Leu would be replaced with Ser. That would be a change in the amino acid sequence and the genetic sequence. That's called a mutation.
yes, you are right, but in the case that i gave the tRNA would also undergo a mutation so that everything would be set right (so even though the mRNA codon specifies a Ser, the anticodon region of a Leu tRNA would be mutated to be complementary to a Ser codon). so in the end, the correct amino acid is added to the peptide even though the genetic sequence has been changed.
i forget what this particular process is called, but it does occur in life.
But the amino acid still ends up being different fron what it originally was supposed to be, hence MUTATION. A mutation is a change in genes and/or chromosomes, etc. It would be considered a point mutation, even though the tRNA mutates to match the mRNA. At least, according to the Biology course I learned this year.
maybe we are miscommunicating...the amino acid that gets put on the peptide does NOT change. the original sequence specified a Leu, the genetic mutation in the DNA changed it to make a Ser, but before the peptide is actually made a tRNA is mutated to make a Leu. Therefore, the peptide is exactly what it was supposed to be.
here is a link that kind-of describes what I'm talking about:
http://www.molbio.uoregon.edu/psaks/trnachng.html
O_O We never learned that when we were learning protein synthesis.
Sorry, but back 2 my initial thing. So, to be clear on it:
The sense strand on the DNA is what actually codes for amino acids, the mRNA uses the antisense strand as a template so that it can get a similar coding scheme as the sense strand, and the anticodon on the tRNA has a sequence that is opposite of both the sense strand on the DNA and on the mRNA, right?
Yes, and as TheLoneWolf pointed out, just remember the difference between DNA and RNA.
My teacher taught us to call it "tag-c" and that way we'd remember T binds to A and G binds to C.
