einsteinian77
- 207
What essentially makes up brain matter? I mean the very composition of neurons.
The discussion centers around the composition of brain matter, specifically focusing on neurons, their structures, and related physiological concepts. Participants explore the differences between gray and white matter, the nature of neuronal connections, and the implications of brain cell death and memory formation.
Participants express a variety of views on the topics discussed, with no clear consensus on several points, particularly regarding the regeneration of brain cells and the specifics of neuronal communication.
Some claims about neuronal function and memory formation are based on ongoing research and may not be universally accepted. There are also uncertainties regarding the exact mechanisms of neurotransmitter action and the implications of brain cell death.
This discussion may be of interest to those studying neuroscience, psychology, or related fields, as well as individuals curious about brain function and cellular biology.
You might be interested at looking at the following picture, it is a cartoon of a neuron. The myelin sheeths you see are actually specialized cells that wrap themselves around the axon, which insulates it. The impuse will actually jump across these 'Schwann cells', from node of Ranvier to node of Ranvier. Some axons can grow up to a meter long, a single cell!Originally posted by einsteinian77
We are born with an excess of neurons, during the first 5 years of life most of these neurons will die if they are not used. We still have an excess though, and throughout life more and more will die, since an unused neuron doesn't get the stimulation it needs to survive.Originally posted by einsteinian77
A couple other questions if you don't mind. Is that myth true that once a brain cell dies it can never grow back? how many connections do neurons have with each other? and do neurons use electricity to communicate through these connections?
Well, I had a whole discussion with Zoobyshoe.. there is a catch phrase: "neurons that fire together wire together". He says the saying is wrong, but it comes down to the following concept:Originally posted by Gale17
How does the whole imprinting thing work? i mean when like a signal is sent through the cells that cell has some sort of memory of it right? er... am i confused, if so straighten me out.
Synapse modification and its dependence on electrical activity.
Experiments in several systems indicate that synapses are strengthened or weakened by electrical activity according to the rule shown in the diagram. The underlying principle appears to be that each excitation of a target cell tends to weaken any synapse where the presynaptic axon terminal has just been quiet but to strengthen any synapse where the presynaptic axon terminal has just been active. As a result, "neurons that fire together, wire together." A synapse that is repeatedly weakened and rarely strenghened is eventually eliminated altogether.
Those are actually along the axon at the nodes of Ranvier, for the propagation of the electrical signal. The sodium ions cause a potential to build.. I DO think that the sodium channels are LINKED to the neurotransmittor gates. So when there is a flux of sodium across the membrane, a flux of neurotransmitter is the consequence.Originally posted by Mentat
Isn't the neurotransmitter mostly composed of sodium ions, which are kept in packets at the end of the axon?
