Calc Elastic Deformation of Copper & Brass Stack
The discussion revolves around calculating the elastic deformation of a stack of copper and brass cylinders under a compressive force. The problem involves understanding the relationship between stress, strain, and Young's modulus in the context of materials science.
  • Mixed
  • Participants explore the application of the formula relating force, Young's modulus, and change in length. There are attempts to calculate the total decrease in length of the stack by summing the individual deformations of the copper and brass cylinders.
Some participants have provided guidance on the need to calculate the area of the cylinders and to ensure proper unit conversions. There is an ongoing exploration of the correct application of formulas and the interpretation of constants involved in the calculations.
Participants note the importance of using consistent units, particularly converting lengths from centimeters to meters. There is also a mention of the need for clarity regarding the dimensions of the cylinders, which are specified as 3 cm and 5 cm in length.
texasgrl05
A copper cylinder and a brass cylinder are stacked end to end, as in the drawing. Each cylinder has a radius of 0.22 cm. A compressive force of F = 6450 N is applied to the right end of the brass cylinder. Find the amount by which the length of the stack decreases.
Is F=Y(change in L/L0)A the equation I would use? I know that Y for brass is 9.0 x 10^10 and Y for copper is 1.1 x 10^11 so would I add those together or what?
Length by which stack decreases= Decrease in length of copper+Decrease in length of brass.
BJ
apparently I'm still doing it wrong:
for copper i got:
6450=1.1*10^11(change in L/3).0022m = 7.9*10^-5
and for brass:
6450=9.0*10^10(change in L/5).0022m = 1.63*10^-4
when i added these together i got 2.43*10^-4
what am i doing wrong?
Stress = Force /area
Strain = Stress/E, where E = Elastic (Young's) Modulus.
What is the meaning of strain in terms of change in length?
1) You need to calculate the area of the cylinders, not just use the radii.
2) What are the units of your constants?
3) You didn't include a picture, so I am assuming that you left out that the cylinders are 3 m and 5 m in length?
yeah the length for the copper rod is 3 cm and for the brass rod its 5 cm..
for copper i got:
6450N=1.1*10^11N/m^2(change in L/3cm).22cm = 7.99*10^-7
and for brass:
6450N=9.0*10^10N/m^2(change in L/5cm).22cm = 1.62*10^-6
when i added these together i got 2.43*10^-6 cm
i still don't think this is right?
You need to use the proper units. Since you are dealing in Newtons, that is broken down into kg*m/sec^2. Sooooo...you need to convert all of your distances from centimeters into meters. Also, the "A" in the equation is for AREA. You keep using the radius of the cylinder in stead of the AREA.
Your first equation should look like:
[tex]6450 N = (1.1 x 10^11 \frac{N}{m^2})(\frac{\Delta L}{.03 m})(\pi * (.022 m)^2)[/tex]
You can solve for [tex]\Delta L[/tex] which will be in meters for each metal.
10K
  • · Replies 17 ·
15K
