Help Needed: Solving Integer Equations with GCD = 1 - Angelo Spina
  • Context: Graduate
  • Thread starter Thread starter angelo
    Gcd Integer
The discussion revolves around three integer equations involving the greatest common divisor (gcd) and prime numbers. Participants explore potential solutions and relationships between these equations, focusing on the conditions under which integer solutions exist with gcd equal to 1. The scope includes theoretical reasoning and mathematical exploration.
  • Angelo Spina presents three problems involving integer equations and asks for help in proving certain properties related to gcd and prime numbers.
  • One participant requests clarification on the background of the problems and the level of mathematical knowledge required to address them.
  • Another participant suggests a method involving triangular numbers and identities to potentially solve problems 2 and 3, although the details remain complex.
  • A later reply indicates a mistake in earlier calculations regarding gcd and proposes a new relation involving Pythagorean triples to derive solutions for the equations.
Participants have not reached a consensus on the solutions to the problems. There are multiple approaches and some uncertainty regarding the correctness of the proposed methods and their implications for gcd.
Some participants express uncertainty about the applicability of their methods and whether they cover all possible solutions. There are also references to specific mathematical identities and relationships that may depend on additional assumptions or definitions.
angelo
I am a visitor of this beautiful site, my name is Angelo Spina, I would like to resolve the three following problems, in fact after many attempts I have not succeeded in it, for this reason I kindly ask you to give me a help.
PROBLEM 1.
If the equation y² + a p² = 2 x² (where a is a positive integer, p is an odd prime number) admits a solution (y,x) of integers with gcd(y,x)=1, how can I prove that the equation y² + p² = 2 x² also admits a solution (y,x) of integers with gcd(y,x)=1 ?
PROBLEM 2.
If the two equations y² + p² = 2 x² , y² + q² = 2 x² (where p and q are odd prime numbers) respectively admit the integer solutions (y',x') and (y '', x '') with gcd(y',x')=1 and gcd(y'',x'')=1, how can I prove that the equation y² + (pq)² = 2 x² also admits at least an integer solution (y*,x *) with gcd(y*,x*)=1 ? Is it possible to find a formula that allows to obtain (y*,x *) from the knowledge of (y',x') and (y '', x '') ?
PROBLEM 3.
If the equation y² + n² = 2 x² (where n is a positive integer greater than 3) admits integer solutions con gcd = 1, how can I prove that the equations
y² + p² = 2 x², y² + q² = 2 x², y² + r² = 2 x², y² + s² = 2 x²,..., (where p, q, r, s,...are the prime factors of n) also admit integer solutions con gcd=1?
Certain of your courtesy, I thank you very much.
Angelo.
Hello and Welcome :biggrin:
Please can you tell us any work you have been able to do on this so far.
May I ask where these question arise from? If it's a basic course in number theory and you've done certain topics presumably these topics are of use in solving the problem (is there a similar problem in the notes/book that is solved)? Roughly what knowledge does this require to solve. If this is a problem from a class field theory text nook then we almost certainly won't know the answer. If its taken from a textbook at a level where observations such as 2 is a quadratic residue mod p^2 and a is a residue mod x^2 and 2x^2 are what the other proofs in the book/notes near to this one are involved then we possibly can help.
The solution starts with the simple identity that if Z is an odd square then (Z-1)/8 equals a triangular number, say A(A+1)/2. Set A(A+1)/2-A(A+1) = -A(A+1)/2 and make the substitution A = (X-1)/2. Multiply both sides of the resulting equation by 8 and substract 1 from each side gives Y^2-2X^2=-Z^2 or Y^2 + Z^2=2*X^2. This solves problems 2 and 3.
I posted the message on 7/2 before leaving to visit relatives. I then realized that my answer gave gcd > 1. I didn't have access to a computer but tried to work the "problem" with using a simple calculator. Unfortunately I used the equation y^2 + 2*x^2 = P^2 instead of y^2 + P^2 = 2*x^2. I will save this work for a separate post. As to the current problem I think the relation 2((x-y)^2+x^2)=(2x-y)^2 + y^2 will help. Simply use the well known relation for Pythagorean triples to get (x-y)^2 + x^2 = X^2 and set P= 2x-y this will give a general equation for solutions to Y^2 + P^2 = 2X^2 but I don't know if it is inclusive of all solutions.
  • · Replies 26 ·
