Loren Booda
- 3,115
- 4
Why is 1 not considered a prime number? It meets the requirement of being only divisible by itself and 1.
The discussion centers around the classification of the number 1 in relation to prime numbers, exploring definitions, conventions, and implications of including or excluding 1 as a prime. The scope includes theoretical considerations and conceptual clarifications regarding number theory.
Participants generally disagree on whether 1 should be classified as a prime number, with multiple competing views presented. The discussion remains unresolved, with no consensus reached on the definition or implications of including 1 as a prime.
The discussion reveals limitations in definitions and assumptions regarding prime numbers, particularly the condition of being greater than 1. The implications of these definitions on mathematical theorems and concepts are also noted but remain unresolved.
i don't see any problem with god given axioms espcecially when "god" itself is man made definition.matt grime said:this kind of question, to my mind, fits in with the ones i get asked a lot like: but why do groups satisfy those 4 axioms. it's almost as if people believe that the axioms we choose are somehow god given, carved in some stone and we must make sense of these mysterious rules that came from nowhere when in fact they are man made.
neurocomp2003 said:no its just if 1 was a prime number then every other number would be a composite and prime which would defeat the purpose of calling it a prime list.
includes this condition, thus effecting parsimony.n is prime iff n has exactly two factors
Why?WeeDie said:I think it's kinda stupid not to see 1 as a prime.
From the beginning of the 19th century, I would believe, since that was approximately the time when mathematicians realized the need to take more care in what definitions they chose to use.Daminc said:How long has 1 not been considered a prime?
WeeDie said:arildo: because the characteristic that makes primes interesting is the fact that they are only devisable by themself and 1. The number 1 serves this condition so I see no need to exclude 1 from the definition of primes. In fact, one might get off on a bad start if one were to exclude 1 and graph primes, in order to find connections between primes and other number series.
I assume that was directed at me.matt grime said:that isn't the proper definition of prime, it is your vwersin of the definition. and in any case it is better stated as "has exactrly two positive factors" since this precludes 1 (and even characterizes primes in the integers as well as the naturals).
matt grime said:it is better stated as "has exactrly two positive factors" since this precludes 1 (and even characterizes primes in the integers as well as the naturals).
matt grime said:erm yes i did just implicitly state the -7 is a prime in Z, and that is perfectly correct and is what the real definition of prime in an arbitrary ring tells us about primes in Z.
HallsofIvy said:Do you consider the Fundamental Theorem of Arithmetic:
"Every positive integer can be written as a product of powers of primes in exactly one way"
stupid?
Calling 1 a prime would make it untrue since then we could write 6= 1*2*3 or 6= 12*2*3 or...
NewScientist said:HallsofIvy,
Just a thought but your reasoning is slightly off
" Calling 1 a prime would make it untrue since then we could write 6= 1*2*3 or 6= 12*2*3 or..."
By the inclusion of 1 - you do not change the numebr of ways a number can be expressed as 1^x is always reducable back to 1 as long as x is a +ve integer (x must be a positive integer otherwise the 1^x term would not be a prime).
So actually 1 - by use of the fundamental theory is not excluded from being prime.
master_coda said:If 1 is a prime, then 3*2*1 and 3*2 and 3*2*1*1 are three different ways of factoring 6 into primes. Pointing out that they all can be reduced to a canonical factorization by eliminating the extra ones doesn't change that fact. You still have different factorizations.
master_coda said:"x must be a positive integer otherwise the 1^x term would not be a prime"? That doesn't make sense; 1^x = 1 for any number x, so if 1 is a prime number than so is 1^x, for any x.
Let pi be the ith prime (so p1 = 2, p2 = 3, etc.). ThenEL said:How about the positive integer "1" then?
NewScientist said:Well..."every positive integer can be written as a product of powers of primes in exactly one way." To express 3, a sa product of primes (it is a positive integer and so must be expressable as a product of primes), one must use 1. if one is not prime (as I know it is not) it does not omit it form this function does it?!
