Finding the charge inside and outside a metal shell
The discussion centers on the electrostatics of a hollow spherical metal shell with a net charge of -100e and a charge of -50e located at its center. The charge on the shell's inner surface is +50e, while the outer surface carries a charge of -150e. The participants clarify that the electric field inside the conductor is zero, but the field within the hollow space is not, allowing for charge separation. The conservation of charge principle is applied to explain the distribution of charges on the shell's surfaces.
  • Understanding of electrostatics and charge distribution
  • Familiarity with Gaussian surfaces and their applications
  • Knowledge of conductors and their properties in electrostatic equilibrium
  • Basic concepts of electric fields and charge conservation
  • Study the principles of Gaussian surfaces in electrostatics
  • Learn about charge distribution in conductors and insulators
  • Explore the concept of electric fields within and outside conductors
  • Investigate the implications of charge conservation in electrostatic systems
Students of physics, electrical engineers, and anyone interested in understanding electrostatic principles and charge distribution in conductors.
mr_coffee
I'm confused on what this even looks like let alone trying to solve it. A ball of charge -50e lies at the center of a hollow spherical metal shell that has a net charge of -100e. What is the charge on (a) the hsell's inner surface and (b) its outer surface? The answers are: (a) +50e; (b) -150e.
I don't get it, i thought the electric field inside a conductor is always 0. I know this is a shell and not a soild conductor but i thought it applys to this case also. :bugeye:
In this situation there is neither a shell by itself, or a solid by itself.
Right...its a charge inside a shell. But I'm still confused on what exactly is going on when they say it has a net charge. If it is a charge of -50e, how can its net charge be -100e? is there another charge somewhere i don't nkow about?
I believe the theory is that the inside of a conductor is always neutral - that there is an equal balance of positive and negative charge. If the total charge of the conductor isn't zero, then the residual positive or negative charge lies on the surface of the conductor.
The conductor in question now is a spherical shell, so both the inside and outside surfaces are candidates for where the residual charge can be located. Since the net charge of the shell is -100e, the sum of the charge of the inner and outer surface must equal -100e.
Like you said, the net field within a conductor is zero. This means that if you take a Gaussian surface that's complete contained inside a conductor, the integral will be equal to zero. In this example, if you were to take a Gaussian surface within the shell, the total charge enclosed would be the sum of the charge from the inner surface and the ball:
[tex]\int E \cdot dA = Q_{enc}/\epsilon_0[/tex]
[tex]\int 0 \cdot dA = (Q_i+Q_b)/\epsilon_0=0[/tex]
[tex]Q_i=-Q_b[/tex]
Q_i is the charge of the inner surface of the shell and Q_b is the charge of ball. As you can see, the charge of the inner surface must be equal and opposite to the ball, i.e. +50e. Since there is a conservation of charge, the sum of the charge of the inner and outer surfaces of the shell must equal -100e, i.e. +50e + ? = -100e. That's how you get part b.
For electrostatic conditions, this means that the field within the conducting material itself is zero. It does not mean that the field inside the hollow space is zero.
The net charge on conductors facing each other is always zero.And hence the first part .If initially the charges on facing conductors are not equal, they would rearrange so that the charges of surfaces facing each other sum up to zero.Further since the charge on the outer plate is finite , that is -100 e , it separates itself into two charges of +50e and -150e , such that the above conditions are also satisfied and charge remains conserved
BJ
I think I'm understanding what everyone is saying, would it be possible for someone to draw a picture showing what's going on?
diagram of charges
I am picturing something along these lines:
http://www.physics247.com/members/advanced/gaussian_surfaces.php
thanks again! it makes sense now!
