Rain's velocity with respect to a moving car
  • Thread starter Thread starter Zem
    Car Velocity
The discussion focuses on calculating the velocity of rain with respect to a moving car traveling due east at 44.4 km/h, where the rain falls vertically and creates an angle of 68.4 degrees with the vertical on the car's windows. The velocity of the rain relative to the car is determined to be 41.3 km/h using trigonometric relationships. The participants suggest using the Pythagorean theorem and trigonometric functions to solve for the rain's velocity with respect to Earth, emphasizing the need to visualize the components of motion.
  • Understanding of basic trigonometry, specifically sine and cosine functions
  • Familiarity with vector components in physics
  • Knowledge of the Pythagorean theorem
  • Concept of relative motion in physics
  • Learn how to apply the Pythagorean theorem to vector problems
  • Study the concept of relative velocity in physics
  • Explore advanced trigonometric applications in motion analysis
  • Investigate real-world examples of relative motion, such as wind effects on aircraft
Physics students, educators, and anyone interested in understanding relative motion and vector analysis in real-world scenarios.
Zem
A car travels due east with a horizontal speed of 44.4 km/h. Rain is falling vertically with respect to Earth. The traces of the rain on the side windows of the car make an angle of 68.4 degrees with the vertical.
(a) Find the velocity of the rain with respect to the car.
My attempt:
I thought perhaps I could model the solution from the problem involving the ground velocity of an airplane, as it flies through a wind that blows a different direction.
sin(theta)/V_rain = sin(90)/44.4 km/h
sin(68.4)/V_rain = sin(90)/44.4 km/h
44.4 km/h(0.930) = sin(90)(V_rain)
V_rain = 41.3 km/h
(b) Find the velocity of the rain with respect to Earth.
(Haven't attempted this one yet.)
All the
Zem
I'd say, with basic trigonometry, [tex]sin\theta = \frac{v_x}{v}[/tex], where [tex]v_x[/tex] is the horzontal speed of the rain (relative to the car), and v the "whole" speed.
b can be solved with tan (or alternatively, the Pythagorean theorem).
My attempt:
V_rain = 41.3 km/h
All the
Zem
Päällikkö has the right idea. You need to visualize what's happening.
There's a vertical component to the rain's velocity - directly towards the Earth. Relative to the Earth, there is no horizontal velocity to the rain.
There's a horizontal component to the car's velocity, but no vertical velocity.
Since your frame of reference in part a is the car, you have a vertical component and a horizontal component to the rain. The horizontal component is equal to the car's velocity (since the car is the frame of reference, the car appears stationary). The rain's linear speed can be found using the Pythagorean theorem and it has to be greater than either of its components.
In this case, you have the angle from the vertical and the horizontal component. Since you have the angle from the vertical, you use straight down as your reference point and rotate 68.4 degrees. You can work your way backwards via:
[tex]sin 68.4 = \frac{44.4}{V_{rain}}[/tex]
Part b can be found using the the answer from part a and the cosine of 68.4 degrees. Or, if you want to stick to the original givens (always gives better accuracy), you can use the tangent.
  • · Replies 20 ·
  • · Replies 16 ·
14K
