Is Charging a 170Ah SLA Battery at 32A Safe?
Charging a 170Ah sealed lead acid (SLA) battery at 32A is within the recommended range, as it aligns with the 0.1C to 1C charging rate guidelines. The maximum charging current should not exceed 1C, which translates to 170A for this battery. However, using a regulated power supply at 13.8VDC for charging is appropriate, ensuring that the voltage remains stable during the charging process. Therefore, charging at 32A is safe and will not damage the battery.
  • Understanding of sealed lead acid (SLA) battery specifications
  • Knowledge of charging current calculations (C-rate)
  • Familiarity with regulated power supply operation
  • Basic electrical safety practices
  • Research SLA battery charging guidelines and best practices
  • Learn about C-rate calculations for various battery types
  • Explore the specifications of regulated power supplies
  • Investigate the effects of overcharging on battery lifespan
Battery technicians, electrical engineers, and hobbyists working with sealed lead acid batteries who need to understand safe charging practices.
cookiebar
What is the max current for a rapid sealed lead acid battery charger?
Most recommend 0.1C up to 1C where C = Ah rating. I have a max 30-32A regulated 13.8VDC power supply and the battery is 12V, 170Ah. Would charging the battery at the max 32A damage the battery?
Please do not double-post.
  • · Replies 21 ·
