learner1
- 5
How can I get the parasitic capacitance of a inductor? I have a scope, current probe, function generator.
Thank you.
Thank you.
The discussion revolves around methods to measure the parasitic capacitance of an inductor, exploring various techniques and considerations in both theoretical and practical contexts. Participants share their experiences and suggestions for measurement approaches using oscilloscopes, function generators, and other tools.
Participants express various methods and considerations for measuring parasitic capacitance, with no consensus on a single best approach. Some methods are endorsed while others are questioned, indicating a range of opinions and techniques in use.
Participants mention potential limitations such as the frequency range of the signal generator, the influence of measurement setup on results, and the need for careful consideration of nearby objects affecting capacitance measurements.
The easiest way will be from its datasheet. There should be a DCR (series resistance) and parallel capacitance listed. Depending on the L and C values, you may have a hard time measuring the resonance with your signal generator. Like if the sig gen only goes to 10MHz, and your inductor is 10uH with 10pF of capacitance, your resonant freq will be around 16MHz. Also keep in mind that your oscilloscope probe has capacitance (probably in the 10pF range), so that will alter your reading and needs to be accounted for.learner1 said:How can I get the parasitic capacitance of a inductor? I have a scope, current probe, function generator.
Thank you.
