Is differentiel equation needed ?
  • Context: Undergrad
  • Thread starter Thread starter Purgum
The discussion revolves around the mathematical modeling of tumor cell growth, specifically whether differential equations are necessary to describe the growth dynamics based on given rates of growth and death. Participants explore the implications of using calculus and differential equations in this context, considering both constant and population-dependent growth rates.
  • One participant inquires about setting up a mathematical formula for tumor growth based on growth rate "m" and death rate "n", questioning the relevance of differential equations.
  • Another participant confirms that differential equations are relevant, suggesting that the dependency of "m" and "n" on time influences the need for calculus.
  • There is a suggestion to integrate the rates over a time interval to find the growth, with a hint about using the linearity of Riemann integrals.
  • A participant explains that if "m" and "n" are constant rates, the growth can be modeled simply, but notes that tumor growth is typically more complex and population-dependent.
  • It is proposed that the growth rate should be proportional to the current population, leading to a differential equation of the form dP/dt = (m-n) * P.
  • Another participant expresses confusion about the formulation of the growth model and requests clarification on the basic concepts involved.
Participants generally agree that differential equations are relevant to the discussion, but there is no consensus on the exact formulation of the growth model or the interpretation of the rates involved. Multiple competing views on how to approach the problem remain present.
Participants mention the dependency of growth and death rates on time and the implications of population size on growth rates, indicating that assumptions about these factors are crucial for modeling. There are unresolved questions regarding the definitions and interpretations of the rates "m" and "n".
Purgum
If a tumor cell grows with rate m, and dies with rate n (m>n), their population number is P, after tme t, how can set up a mathematical fomuler for growth ? If i also have data from 100 patients, is it useful ?
Dos my problem have relations with differentiel equations ? How can i find exact growth at t time after all ?
VERY URGENT NEED HELP[/size]
Thanks
Yes.
"Do you have to use calculus?" That depends on the dependency of m and n. Are they functions of time? If so then to find out how fast the tumor grows you will need to integrate over both m and n over a certain time interval and calculate the difference (hint: use linearity of riemann integrals for a nicer looking equation).
P.S.
You really shouldn't triple post.
Berislav said:
Yes.
P.S.
thank u, but my question is about htree differtn things :confused:
but can u explain to me basic things bout that? i don understand why how people can fomute that fomuler.. can u help ?
The formula you need will depend on exactly what you mean by rate. If you mean that the tumor cells grow at a constant rate of "m" cells per second and die at a constant rate of "n" cells per second, then its easy to see that the number of cells "t" seconds later is P(t)= P(initial) (m-n)t, because after every second there will be (m-n) more cells than before.
However, this is not the sort of growth you would expect from tumor cells. You would expect that if all of the cells are dividing indepently of one another, the rate of growth would depend on the current population. For example, if one cell divides once in one hour, and you only have one cell, the rate of growth for one hour would be 1 cell per hour. Now suppose you have a thousand cells. After one hour they each divide once, so you now have two thousand cells. This means the rate of growth for that hour is 1,000 cells per hour. Notice that the growth rate is propotional to the current population. I have been looking at the growth rate over finite intervalt by taking [tex]\frac {\Delta P} {\Delta t}[/tex] but with more and more cells dividing indepently of one another, growth rates over smaller intervals start making sense and we can make the approximation [tex]\frac {\Delta P}{\Delta t} \approx \frac {dP} {dt}[/tex] Now, if this is the sort of growth we're talking about, then "m" probably doesn't measure new cells per hour, but more likely new cells per hour per existing cell. Likewise "n" would be in cells lost per hour per existing cell. The net growth rate would then be (m-n) cells per hour per existing cell. The growth rate is proportional to the number of existing cells. Since the growth rate is [tex]\frac {dP} {dt}[/tex], the equation that expresses this idea is [tex]\frac {dP} {dt}= (m-n) \times P[/tex]
  • · Replies 25 ·
  • · Replies 0 ·
