Nuclear Fusion Reactor & Power Plant: Issues & Challenges
  • Thread starter Thread starter FEBAUSA
    Fusion
The discussion revolves around the challenges and issues related to the development and continuous power production of nuclear fusion reactors and power plants. It encompasses theoretical, technical, and experimental aspects of fusion energy, including the feasibility of achieving breakeven and the various confinement methods employed in fusion research.
  • Experimental/applied
  • Some participants highlight that achieving breakeven, where the energy output equals the energy input, remains a significant challenge in fusion research.
  • Magnetic confinement, such as in tokamaks, is discussed as a common approach, but it faces issues with plasma instabilities that prevent sustained reactions.
  • Inertial confinement fusion is presented as an alternative, relying on creating a dense plasma that burns quickly, but it struggles to achieve the necessary conditions for ignition.
  • There are mentions of various research facilities, such as the National Ignition Facility and the Laboratory for Laser Energetics, which are working on advancing inertial confinement techniques.
  • One participant questions the feasibility of replicating a star's structure using lasers, suggesting that such an approach would not maintain stability due to the lack of sufficient mass and gravity.
  • Another participant shares enthusiasm for fusion as a topic and notes the availability of undergraduate courses on the subject, referencing a specific textbook used in the field.
Participants express a range of views on the challenges of nuclear fusion, with no consensus on the best approach or the feasibility of certain ideas, such as replicating stellar conditions on Earth.
Limitations include the unresolved nature of achieving breakeven, the dependence on specific definitions of confinement methods, and the ongoing experimental challenges faced in fusion research.
FEBAUSA
Question about fusion...
What are the problems for development, continuouly power production and economical, in a nuclear fusion reactor and nuclear fusion power plant ?
It takes more energy to create and sustain the reaction than it produces. One of the most common approaches used magenetic fields to contain the reaction, but that takes more energy than the reaction generates, for example,
FEBAUSA,
In a word - "breakeven".
As of yet, we don't know how to achieve "breakeven" - that is to get as
much energy out of the plasma as we put into make the plasma.
The basic approaches to fusion are "magnetic confinement" and
"inertial confinement".
Magnetic confinement uses machines like "tokamaks" to confine the
plasma with magnetic fields. The problem there is that a magnetically
confined plasma has all sorts of instabilities - and it breaks up before
we can hold it long enough to get back as much energy as we put into it.
Magnetic confinement is chiefly studied at the Princeton Plasma Physics
Laboratory:
http://www.pppl.gov/
The other approach is "inertial confinement" fusion. Here, you don't
even attempt to try to "hold" the plasma. You create a very dense
plasma that burns very fast, and you count on the fact that the inertia
of the mass of the plasma will hold it together long enough to get
useful energy. The confinement time will be very short - but if the
fusion burn is fast enough - you could still get a useful amount of energy.
[ After all, that's how hydrogen bombs work - they don't hold together
very long - but they produce energy so fast that the small confinement
time is long enough ].
The problem with inertial confinement fusion is that we haven't been
able to create a plasma large enough to trap the alpha particles which
you want to do to get "ignition". That is, just as a fire uses the heat from
combustion to keep the fire going - you want to trap the alpha particles
to keep the fusion fire going. Previous experimental machines couldn't
do that - but that is changing.
The principal means of heating and compressing a plasma in inertial
confinement fusion is with lasers - also called "laser fusion". The
principal research centers are at Lawrence Livermore National Lab,
and the Laboratory for Laser Energetics at the University of Rochester.
Lawrence Livermore National Laboratory is building the NIF - the
National Ignition Facility. This 192 beam laser should be powerful
enough to create a plasma large enough to achieve ignition. The NIF
building is finished, as are the first set of lasers. More lasers will be
brought online during the next few years until the entire 192 beam
complement of lasers is finished. See:
National Ignition Facility at Lawrence Livermore National Laboratory:
http://www.llnl.gov/nif/
http://www.llnl.gov/nif/project/index.html
http://www.llnl.gov/nif/project/news_nel1.html
OMEGA laser at the Laboratory for Laser Energetics at University of Rochester:
http://www.lle.rochester.edu/
Another method for inertial confinement is to use large pulsed power
sources to "magnetically implode" plasmas in what is called "Z-pinch
inertial confinement fusion". This research is underway at the
Sandia National Laboratory in Albuquerque, New Mexico:
http://www.sandia.gov/pulsedpower/
http://www.sandia.gov/LabNews/LN09-24-99/fusion_story.html
http://zpinch.sandia.gov/
http://www.sandia.gov/media/z290.htm
http://zpinch.sandia.gov/Z/Images/z.jpg
Hope that's enough to get you started.
Dr. Gregory Greenman
Physicist
Nice post Morbius! I always enjoy reading your comments.
pallidin,
Thank You
Physicist
Antiphon's question has been split into it's own thread
What are projects about nuclear controlled fusion reactor to achieve Q > 1, or possibly obtain Q > 1.
Fusion is my favorite topic to discuss and read. I just found out from a friend today that undergraduates can take classes dealing with fusion, they used to only be graduate level. I looked around and found that Dr. Weston "Bill" Stacey, a former director of Argonne's fusion program, could be my professor!
Has anyone heard of the text that is used: W. M. Stacey, Fusion Plasma Analysis, 1st Edition, Krieger, 1981?
Yeah, I have that book and used parts of it when I taught Fusion Engineering almost 20 years ago. I also used Dolan, but it's a set of three, which are hard to find, and I misplaced or lost Parts 2 and 3.
Hi Morbius.
I have a question that I think you are very capable of answering.
Do you think that by using an array of LASERs that we could literially paint a high energy image or Photosphere shell like the sun has, but as a miniature version or virtual duplicate of a miniature star with shell and core structures?
Do you think cloning a stars exact exterior and interior structure would be an effective means to copy the exact process within the star itself? .ie Holographic Sun created by LASER interference.
Thanks. :smile:
OnTheCuttingEdge2006 said:
Hi Morbius.
Thanks. :smile:
In a word: NO.
You aren't going to be able to "paint" or "copy" a miniature version of the Sun.
For one thing; even if you did - it wouldn't stay the way you copied it.
Suppose you made a ball of high temperature, high density plasma similar to what one
finds in the interior of the Sun. It wouldn't stay that way - it would explode.
The Sun is like a great big exploding Hydrogen Bomb. However, this Hydrogen Bomb
is so massive that its gravity opposes the explosion and keeps the Sun stable.
Without all that mass - and the consequent gravity - there's nothing to hold your plasma
intact - so it would just explode.
In a way, the fusion targets at Livermore are like these little exploding Suns.
However, they won't have a photosphere. You get a photosphere when the distances
that the photons of light travel are much, much less than the diameter of the object.
Clearly, our little exploding suns are much too small to have photospheres.
We can't just copy the ways stars do things - we have to do things that make sense on
Earth - with the quantities of mass that we have available.
Physicist
  • · Replies 23 ·
  • · Replies 19 ·
