mceddy2001
- 21
Why do atoms want a full outer shell
The discussion centers on the reasons why atoms seek to achieve a full outer shell of electrons, exploring the underlying principles of atomic stability and electron configuration. Participants delve into quantum mechanics, electron spin, and the implications of Hund's Rules, while also questioning the adequacy of existing explanations.
Participants express a range of views on the reasons behind atomic stability and the role of electron configurations. There is no consensus on a singular explanation, and multiple competing perspectives remain throughout the discussion.
Participants highlight the complexity of atomic behavior and the limitations of existing guidelines, indicating that further exploration is needed to fully understand the motivations behind electron configurations. Some assumptions and definitions remain unresolved, particularly regarding the nature of stability and the role of spin.
Originally posted by benzun_1999
the answer for your question is simple.
To attain stable electronic configuration they they try to have full the outermost orbit or valence orbit.This is done by losing or gaining electrons.
Originally posted by mmwave
My understanding is that the label +- 1/2 is just to remind us that there are only two possibilities. They are often called up and down and could have been called left and right but +- 1/2 stuck.
(1) A half filled shell is stable? I guess you could say it's stable, in the same sense that every nonradioactive atom has a stable configuration, regardless of how full or empty the valence shell is. Iron "turns into" rust because it prefers a "full" valence shell, regardless of how "stable" it is as atomic iron. I think the question is more, "why do atoms want to fill their shells the way they do?" not, "why is a full valence shell a stable configuration?"Originally posted by futz
(1)
The reason why a full shell is more stable is more or less the same reason a half-filled shell is stable.
(2)
There are a set of guidelines called Hund's Rules which are used to determine the ground state electron configuration of a particular atom.
(3)
The underlying principle is that electrons fill orbitals in such a way as to minimize the total energy of the atom. ... the atom wants to have the largest number of parallel spins that it can ... The reason for this is as follows: two spins that are parallel "don't like each other", so they will tend to push apart. This decreases the Coulomb energy between them, lowering the overall energy ...
(4)
... to fully detemine the electron configuration, we need to apply the rest of Hund's rules (2 of them), which are more complicated, and break down for certain elements.
(1) Alright, I'll buy that.Originally posted by futz
(1) By stable, I simply meant it is generally more stable than certain other configurations, say half filled plus 1.
(2) The 1s subshell (n=1, l=0) can hold two electrons. Once the first one goes in, the second has no choice but to go in antiparallel to the first. Energy is still minimized, even though the spins aren't parallel (usually, electrons will fill one subshell before moving onto another, at least in this case).
(3) By the way, all 3 rules are based on minimization of energy: ...
Whether or not min. of energy is the only force behind the electron's behavior, I guess I honestly don't know. All of my courses listed it as such. [/B]
Originally posted by barcat
I need to ask. Is there really such a thing as and unbalanced atom? If there is, is this the reason for "Brownian Motion"?
