Magnitude of net electric field
The problem involves calculating the magnitude of the net electric field at the center of a square formed by four point charges, three of which are positive and one negative, each with a magnitude of 2.2 x 10^-12 C. The square has a side length of 3.0 cm.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the formula for electric field strength but expresses uncertainty about combining the electric fields from multiple charges. Other participants question the validity of the formula used and the calculations performed.
The discussion includes attempts to calculate the electric field using a specific formula, with some participants exploring the reasoning behind the calculations. There is a moment of realization from the original poster, indicating a potential breakthrough in understanding, though details remain unclear.
Participants are navigating the complexities of combining electric fields from multiple charges and are working within the constraints of the problem setup without providing a definitive solution.
mayo2kett
Four point charges have the same magnitude of 2.2 10-12 C and are fixed to the corners of a square that is 3.0 cm on a side. Three of the charges are positive and one is negative. Determine the magnitude of the net electric field that exists at the center of the square.
i tried using E=(k|q|)/r^2 but it wasn't working and I'm not sure how to combine the electric fields for all of the outside charges...
-annie
Why doesn't that formula work?
this is what i tried ((8.99e9)(2.2e-12))/((3.0e-2)^2) and i got 21.976... so now am i supposed to multiply by 4? cause that answer i got isn't right
-annie
ahha i figured it out... :)
  • · Replies 17 ·
