Calculating Internal Resistance and EMF of a Voltage Source
  • Thread starter Thread starter BDR
    Emf Voltage
The discussion revolves around calculating the internal resistance and electromotive force (emf) of a voltage source based on changes in terminal voltage and current. Participants are exploring the relationships between voltage, current, and resistance in the context of electrical circuits.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the equation V = E - Ir and its implications for understanding internal resistance. There are questions about the adequacy of the provided information and how to relate changes in voltage and current to the internal resistance. Some participants express uncertainty about the correct interpretation of the equations and the graph of V vs I.
The discussion is active, with participants sharing their reasoning and attempting to clarify their understanding of the relationships involved. Some guidance has been offered regarding the interpretation of equations and the implications of the graph, but there is no explicit consensus on the final answers.
Participants note the challenge of having multiple unknowns (E and r) and question whether certain variables can be simplified or omitted from their calculations. There is an ongoing exploration of how to correctly apply the equations given the changes in voltage and current.
BDR
Hello everyone!
I have a question and any help would be appreciated!
(a) What is the internal resistance of a voltage source if its terminal voltage drops by 2.00 V when the current supplied increases by 5.00 A?
(b) Can the emf of the voltage source be found with the information supplied?
BDR said:
Hello everyone!
What do you know about the relationship between voltage current and resistance? Show us some attempt to solve this problem, and then you can get help.
https://www.physicsforums.com/showthread.php?t=4825
I know that the internal resistance of a voltage source affects the output voltage when a current flows. I was thinking that I would use the equation V = E - Ir...but I seem to get a different answer each time I use it. I also know that V = IR.
Im my view of this problem I do not have enough information to work the problem with the above equations. Am Ii close?
From V = E - Ir you know what a graph of V vs I should look like. E is the emf (unknown, but constant) and r is the internal resistance (also an unknown constant). The information tells you how much V changes for a change in I. Relate that information to the graph of V vs I and you will have the answer to part a). If you think about trying to draw the graph using the information given, you will also know the answer to part b).
also write what you know in equation form:
[tex]V_{1} \ = \ E - I_{1}r[/tex]
[tex]V_{2} \ = \ E - I_{2}r[/tex]
[tex]V_{2} - V_{1} \ = \ (E - I_{2}r) - (E - I_{1}r)[/tex]
[tex]V_{2} \, - \, V_{1} \ = \ -2 \ \mbox{Volts \ \ WHEN} \ \ \ I_{2} - I_{1} \ = \ \mbox{+5 amps}[/tex]
can you now solve for internal resistance r?
I'm sorry, but I guess I am not understanding about how I get the information from the graph. Since E and r are unknown constants; does that mean that I could leave them out of the equation and just have V = I? Or am i making it harder than it really is?
Is this close? 2V = E - (5 A)r
you didn't simplify the following equation correctly:
what happens to E?
The E's would cancel each other out? But it seems to me there are more variables than numbers for this problem.
write the full (simplified) equation:
[tex]V_{2} - V_{1} \ = \ (E - I_{2}r) - (E - I_{1}r) \ = \ I_{1}r \, - \, I_{2}r \ = \ (I_{1} \, - \, I_{2})r[/tex]
then use what you know:
[tex]V_{2} \, - \, V_{1} \ = \ -2 \ \mbox{Volts \ \ WHEN} \ \ \ I_{2} \, - \, I_{1} \ = \ \mbox{+5 amps}[/tex]
Lets see if i understand: -2 V = 5r...r = -2/5??
almost!
what is the sign of (I1 - I2) in the following equation?
look carefully. it's a little tricky. remember:
[tex]V_{2} \, - \, V_{1} \ = \ -2 \ \mbox{Volts \ \ WHEN} \ \ \ \color{red}I_{2} \, - \, I_{1} \ = \ \mbox{+5 amps}[/tex]
Is this what you mean...I1 - I2 would be negative, causing a +2/5...right?
congratulations!
r = 2/5 ohms
Thanks for the help, its greatly appreciated!
13K
