Do White Holes Really Exist and What Are Their Properties?
The discussion revolves around the existence and properties of white holes, exploring their theoretical implications in relation to black holes and the big bang. Participants delve into speculative ideas about the nature of white holes, their potential formation, and their connection to cosmological phenomena.
  • Speculative reasoning
  • Some participants propose that white holes, or "white divergences," diverge and repel matter, contrasting with the converging nature of black holes.
  • There is speculation about a connection between white holes and the big bang, with one participant suggesting that the universe itself could be a white hole.
  • Another viewpoint suggests that white holes might be formed from superdense pockets of dark energy.
  • One participant introduces the idea that black holes could be 5D objects, leading to a curvature of space-time that could relate to the properties of white holes.
  • A claim is made that the edge of the universe could be akin to a gigantic white hole, potentially radiating energy similar to cosmic background radiation.
  • Some participants express skepticism about the stability of white holes, emphasizing the need for mathematical and 3D simulations to analyze their properties.
  • There are speculative notions about white holes being points of less than zero mass, contrasting with singularities that have infinite mass.
  • One participant suggests a cyclical relationship between black holes and white holes, proposing a multiverse concept where each black hole could lead to a white hole.
  • Another participant shares a philosophical perspective, likening the universe to a boolean state where matter cannot exist without space.
Participants express a range of speculative ideas about white holes, with no consensus on their existence or properties. Multiple competing views and hypotheses remain unresolved throughout the discussion.
Some claims rely on unverified assumptions and lack mathematical backing. The discussion includes speculative reasoning that may not adhere to established theories or definitions in physics.
paul_abbotts
Hi,
Do white holes exist? If not why not? If a white hole is the opposite of a black hole then it will have the following properties:- Black holes converge, localise or attract matter towards a point. white holes diverge, non-localise or repel matter. White holes should therefore be called white divergences they are not holes at all, they are the opposite of a point structure. If black holes slow down time form our perspective then a white divergence must speed up time (time contraction) and dilate distance. This effect is equivalent to a spherical reverse telescope effect whereas a black hole has an associated spherical telescope effect or magnification. If black holes are cold due to massive time dilation then a white divergence must be superhot due to time contaction. Is there a connection between the big bang and a white divergence? By definition there can only be one white hole the one we seem to be living in. It is interesting to note that a spherical reverse telescope effect will produce an increasing red shift just like the big bang!
Space news on Phys.org
There are many differences between the big bang and the properties of a theoretical white hole. You can't really analyze all this with just the words from popular articles; you need the math. Both the big bang and black (and white) holes are solutions of Einstein's field equations for particular cases. But the cases are different.
Hi,
Maybe white holes are formed from superdense pockets of dark energy.
juju
paul_abbotts said:
Hi,
White holes should therefore be called white divergences they are not holes at all, they are the opposite of a point structure. ... Is there a connection between the big bang and a white divergence? By definition there can only be one white hole the one we seem to be living in.
I had similar (speculative) thoughts. Black holes are sometimes suggested to be 5D objects. That allows a curvature and closure on cosmological scale of 4D space-time in the 5th dimension. An observer should then see the same effect of that curvature in the far distance of the universe as he does near a black hole, i.e., objects in the far distance of the universe should show redshift, purely as a result of the space-time curvature in 5D.
Now we could speculate that the "edge" of the universe is in fact the "inside" of all black holes together, thus closing the circle in 5D. What we see is just the other side of the Schwarzschild radius. That means that whatever falls into a black hole will appear again instantly at the "edge" of the universe. It suggests that the edge of the universe is in fact a gigantic "white hole" and should therefore radiate energy (cosmic background radiation?).
In Euclidean relativity the 4-velocity of all objects is always [itex]c[/itex]. That also works in 5D if you assume a rotation of the 5-velocity vector towards the axis of [itex]x_5[/itex] when an object falls into a black hole. At the universe's "edge" where the object shows up again, this velocity begins to rotate back again. See the attached GIF file that shows the path of the 5-velocity rotation (it's actually an animated GIF but that doesn't show in this forum. You can also find it http://www.rfjvanlinden171.freeler.nl/idea/blackhole.gif).
Individual velocity components for the falling object are the coordinate velocity in 3-dimensional space:
[itex]V(r)=\{1-2MG/(rc^2)\}\sqrt{2MG/r}[/itex],
the velocity in the time dimension [itex]x_4[/itex]:
[itex]T=c\sqrt{1-2GM/(rc^2)}[/itex]
and the velocity in [itex]x_5[/itex]:
[itex]V_5=\sqrt{c^2-T^2-V(r)^2}[/itex].
I have never checked the remaining math of this idea completely (and don't feel very able to do so either) so don't take it too serious.
I was talking to a friend a few days ago and the topic of white holes came up. I suggested that white holes were a point inspace were there was less than zero mass.
(a singularity is a point of infinite mass, thus an anti-singularity would have infinite "nullity")
Theory
Perhap's we have been looking for the white hole in the wrong place. Since a black hole, forgive this, compresses into a singularity, then is it not logical that a white hole does the opposite? Perhap's the "Big Bang" was not an event, in the normal sense, but the beginning of a white hole which exist still? In other words, the "white hole" is the known universe inwhich we exist. Simple, yet logical. Do not ask for mathmatical theorem, I have none to support it. But it would support the idea of a multiverse in that numerous black hole's would be gateway's to numerous white holes. Paradox in that "when did time start?" "What is the point of origin of gravity?" Logical to assume that one beget's the other in a loop, as a mobius strip.
My expertise lie in, heh, liberal art's. I can only base this on my career experience: a fugitive's past whereabout's being that of a black hole, the fugitive being a singularity, and his proposed future whereabout's being a white hole. Logical profiling which has worked quite well for me.
you not only need math but 3D simulations. From what i learned from my project on white holes in my astrophysics courses ...they can't be stable.
The Universe in my opinion is boolean, If you remove the space from (ALL) matter then you would have no matter at all.
Quoted from the movie, Matrix: There is no spoon!
Just my opinion though.
Gerald L. Blakley
Electron Microscope of Gold Atoms
Here is an Electron Microscope image of Gold Atoms, Notice how they look like cotton balls or Cumulous clouds.
Gerald L. Blakley :smile:
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 45 ·
9K
