On the Relativity of Lengths and Times
  • Context: Graduate
  • Thread starter Thread starter paco1955
    Relativity
The discussion revolves around the concept of length contraction in the context of special relativity, specifically how to measure the length of a moving rod from a stationary frame of reference. Participants explore the implications of synchronizing clocks and the physical aspects of measurement in different frames of reference.
  • One participant questions how to ascertain the exact positions of the ends of a moving rod at a specific time for measurement, indicating uncertainty in the measurement process.
  • Another participant suggests that the inquiry relates to deriving length contraction using Lorentz transformations, providing a mathematical approach to the problem.
  • A different participant expresses doubt about whether the original question is about deriving length contraction, instead focusing on the physical aspects of how stationary observers can accurately measure the rod's length at a specific time.
  • Some participants propose that multiple stationary clocks along the x-axis can help determine the positions of the rod's ends, with observers at each clock marking the times when they see the rod's ends.
  • There is mention of the concept of proper time and its relation to measuring length, raising questions about the necessity of knowing the rod's velocity for accurate measurement.
Participants express differing views on the focus of the question, with some emphasizing the mathematical derivation of length contraction and others highlighting the practical aspects of measurement. No consensus is reached on the primary concern of the inquiry.
Participants note the potential need for additional assumptions regarding the synchronization of clocks and the definition of proper length, which remain unresolved in the discussion.
paco1955
let there be given a stationary rigid rod; and let its length be l as measured by a measuring-rod which is also stationary. we now imagine the axis of the rod lying along the axis of x of a stationary system of co-ordinates, and that a uniform motion of parallel translation with velocity v along the axis of x in the direction of increasing x is then imparted to the rod. we now inquire as to the length of the moving rod, and imagine its length to be ascertained by the following operation:
by means of stationary clocks set up in the stationary system and synchronizing, an observer ascertains at what points of the stationary system the two ends of the rod to be measured are located at a definite time. the distance between these two points, measured by the measuring-rod, is a length which may be designated "the length of the rod".
how does the observer ascertains the points of the stationary system at which the two ends of the rod to be measured are located at a definite time?
i do not know how to ascertain the two points on the axis of x in order to measure the distance between them.
need help
thanks
I believe your question amounts to deriving length contraction?
You can do this with Lorentz transformations... let S' be the moving frame, and S the stationary frame. [tex]\gamma = \frac{1}{\sqrt{1-v^2/c^2}}[/tex]
The left end of the rod (the rod is moving towards the right) has equation:
[tex]x_1' = 0[/tex]
so
[tex]\gamma (x_1 -vt_1) = 0[/tex] (eq 1)
The right end:
[tex]x_2' = L[/tex]
so
[tex]\gamma (x_2 - vt_2) = L[/tex] (eq 2)
eq. 2 - eq. 1 gives:
[tex]\gamma (x_2 - x_1 - v(t_2 - t_1)) = L[/tex]
but [tex]t_2 = t_1[/tex]
so
[tex]\gamma(x_2 - x_1) = L[/tex]
So [tex]x_2 - x_1 = L/\gamma[/tex]
So the length as measured in the stationary frame is: [tex]L/\gamma[/tex]
learningphysics: I believe your question amounts to deriving length contraction?
I am not sure that is the question. He wants to know, or I am wondering about, the physical aspects of how the stationary crew can be so positioned that they know the exact spots on the ground at time t_0 that the length is being accurately measured. (It seems it would be easier to measure the time elapsed from the same stationary point, but then we need to know the velocity.)
paco1955,
You can assume there are lots of stationary clocks along the x-axis and an observer standing by each one.
As the rod goes by, one observer will see the front of the stick at his location at t=0 (or whaterver). Another observer will see the back of the rod at his location at t=0. the distance between these two observers in the stationary frame is "the length of the rod" as measured in the stationary frame. this length will of course be less than the proper length, the length of the rod in the moving frame.
jdavel: You can assume there are lots of stationary clocks along the x-axis and an observer standing by each one.
Sartori in Understanding Relativity seems to take this for granted.
He also talks about the proper time, which is two measurements of time at the same clock. Yet to measure the length this way we would need to know the velocity. This seems to require a reading of length?
  • · Replies 166 ·
16K
  • · Replies 84 ·
  • · Replies 33 ·
  • · Replies 35 ·
  • · Replies 21 ·
