Maximizing Velocity Excess: The Power of Perihelion Gravity Assists
  • Context: Graduate
  • Thread starter Thread starter rieman zeta
    Gravity
The discussion revolves around the mechanics of maximizing velocity excess at infinity when firing rocket engines at perihelion during a spacecraft's trajectory around the Sun. Participants explore the implications of conservation laws and the effects of velocity changes on energy and angular momentum within the context of orbital mechanics.
  • Some participants suggest that firing rockets at perihelion maximizes velocity excess due to conservation of total energy and angular momentum.
  • One participant requests clarification on the specific orbits and osculating elements involved in the discussion.
  • A scenario is presented where two spacecraft perform burns at different points in their orbits, with the second spacecraft firing at perihelion yielding greater velocity excess at infinity.
  • Another participant explains that the rocket gains the most energy per unit velocity change when it thrusts in the direction of motion and is moving fastest, emphasizing the non-linear relationship between velocity and kinetic energy.
  • Discussion includes calculations of angular momentum and velocity changes at various points in an elliptical orbit, noting how these changes affect apogee and perigee.
  • One participant highlights that the effect of a maneuver is greater when performed at perihelion, as it focuses the impact on the opposite side of the orbit.
  • Another participant illustrates that the kinetic energy gained from a velocity increase is greater when starting from a higher initial velocity, reinforcing the importance of the burn's timing.
Participants express various viewpoints regarding the mechanics of velocity excess at perihelion, with some agreeing on the importance of conservation laws while others emphasize different aspects of orbital dynamics. The discussion remains unresolved with multiple competing views on the optimal conditions for maximizing velocity excess.
Some participants note the dependence on specific orbital parameters and the assumptions made regarding the spacecraft's trajectory and burn characteristics. There are unresolved mathematical steps and varying interpretations of the effects of burns at different orbital points.
rieman zeta
why does firing your rocket engines (obviously in the appropriate direction) at perihelion give the greatest velocity excess at infinity?
Astronomy news on Phys.org
two reasons
1) conservation of total energy
2) conservation of angular momentum
Check out : http://www.dur.ac.uk/bob.johnson/SL/
regards
marlon
could you be a little less opaque please. jbf
Well, i do not really feel like writing down all the equations involved so i ask you to be a little bit more specific and throw in some formula's to illustrate your question. Which orbits are we dealing with here ? What osculating elements are you using ? You see my point ? What have you done yourself ?
What i wanted to say with my first post is the fact that all the formula's that you use will be a result of applying the two mentioned laws onto the orbits and object's motion.
marlon
powered gravity assist
sir: A spacecraft with rocket capability approaches the sun from infinity in a parabollic orbit. It has a twin folowing. The first fires its rockets tangent to its trajectory and opposite the direction of motion at 3 times the radius of the Sun. Later, the second waits until it is at perihelion (2 solar radii) before firiing an identical burn, force x del t. Why is it when they compare their velocity excess at infinity is the second's greater than the first?
This is a strictly two body problem done in heliocentric coordinates.
Of course it is your choice to give an answer couched in whatever orbital mechanics equations seem to bear. Ususally there is a direct explanation related to a well recognized physical principle.
If there is some necessity to frame the question with more clarity please advise again.
jbf
I'm assuming that the problem description is that the rocket accelerates in the direction it is currently moving with respect to the sun (which is essentially the center of mass of the solar system), and that the rocket has a fixed delta-v capability.
Assume that the rocket burns very fast, so it essentially gives an impulse to velocity.
As another poster stated, there are two important parameters that determine the shape of the orbit, angular momentum and energy.
In this case, we are concerned with the total velocity at infinity, which is initially zero.
"Velocity at infinity" is just another name for energy, so we are concerned with the rocket's total energy, which is assumed to be conserved - this will be exactly true in center-of-mass, i.e. heliocentric, coordinates if the rocket doesn't interact with any other planets, and approximately true if it doesn't have any close encounters with other planets.
The rocket gains the most energy per unit velocity change when it thrusts in its direction of motion (which has been already assumed), and when it is moving the fastest.
This is because energy is not linear, it's .5*m*v^2 + V(r), where V(r) is the potential energy, and v is the rocket's velocity.
To illustrate: a rocket at a velocity of 6 has 18*m units of energy, at a velocity of 8 it has 32*m units of enregy, and at a velocity of 10 it has 50*m units of energy. The rocket which accelerates from a velocity of 6 to 8 gains 14*m units of energy, while the rocket that accelerates from a velocity of 8 to 10 gains 18*m units of energy.
You get a better picture if you start with an elliptical orbit. That way you can compare apogee, perigee, and some point between.
What you'll find is that the change in angular momentum is directly proportional to the change in velocity.
If perigee is 7500km and the initial velocity is 8928.6 m/s, then the angular momentum is 66964.6 km^2/s. If you increase the velocity by 1000 m/s, the satellite is going 1.112 times as fast as its initial perigee velocity. The angular momentum is also 1.112 times as great, or 74464.6 km^2/s. The eccentricity increases from .5 to .8548 and apogee of the orbit increases from 22500 km to 95816 km. Perigee remains unchanged since that's where the maneuver occurred.
If apogee of the same orbit is 22500 and the apogee velocity is 2976.2 m/s, then the angular momentum is still 66964.6 km^2/s (angular momentum is conserved). If you increase the velocity by 1000 m/s, the satellite is going 1.336 times as fast and the angular momentum is 1.336 times greater, or 89464.6 km^2/s. The eccentricity of the orbit decreases from .5 to .10755 and perigee increases from 7500 to 18130 km. Apogee remains unchanged since that's where the maneuver occurred.
You can probably anticipate what's going to happen if you do the maneuver at the covertex (true anomaly equals 120 degrees). Before the maneuver, your speed (now there's two components to the velocity since you're not at perigee or apogee) is 5154.9 m/s with angular momentum conserved. Increasing the speed by 1000 m/s results in a speed 1.194 times as fast and angular momentum is 1.194 times as great, or 79954.96. The eccentricity of the orbit increases, but only to .62117. Both perigee and apogee increase - perigee to 9892.9 km and apogee to 42336.4 km.
A maneuver at the opposite covertex (as you go from apogee to perigee) gives the exact same results with one difference. At 120 degrees, the argument of perigee progresses and true anomaly regresses. At 240 degrees, the argument of perigee regresses while true anomaly progresses.
The further away from the Earth you perform a maneuver, the bigger effect it will have on the orbit. However, performing the maneuver at perigee focuses all of the effect towards the opposite side - hence a greater impact on apogee even though the effect on the orbit overall is less.
Edit: I reread your more detailed post. Once you've set your angular momentum, it remains constant. A maneuver at perigee has the least affect on the orbit's angular momentum, but increases apogee. That means there must be a proportional decrease in velocity at apogee if angular momentum will remain constant. An given increase in speed at perigee will result in a lower velocity at apogee than an increase anywhere else in the orbit.
Except your specific example talked about decreasing the speed instead of increasing it. If the speed is decreased, the effects are the opposite. A decrease in speed has the least effect on the orbit's angular momentum, but the greatest effect on the apogee radius. Since angular momentum remains constant once set, there has to be an increase in apogee speed to offset the decrease in apogee radius.
The simple reason: firing your rockets will add the same amount of velocity no matter where. But, kinetic energy is velocity^2, so the faster your starting velocity is the more energy you gain.
example: going 3km/s your energy is 9 units. add 1 km/s and energy is 16. You get 7.
going 4km/s and adding 1km/s makes you gain 9 kinetic energy units
  • · Replies 86 ·
9K
  • · Replies 19 ·
  • · Replies 30 ·
  • · Replies 21 ·
