How Do You Calculate the Peak EMF of a Rotating Coil in a Magnetic Field?
  • Thread starter Thread starter mayo2kett
    Electric Generator
The discussion revolves around calculating the peak electromotive force (emf) of a rotating coil in a magnetic field, specifically in the context of a generator. The problem involves parameters such as the radius of the coil, the length of the wire, the magnetic field strength, and the angular speed of rotation.
  • Participants discuss the initial approach using the formula for induced emf in a rod, questioning its applicability to a rotating coil scenario. They explore Faraday's law and the relationship between magnetic flux and induced emf, suggesting a need to consider the changing area of the coil over time.
Some participants have provided guidance on applying Faraday's law and have prompted further exploration of the relationship between the angle of rotation and time. There is an acknowledgment of the need to find the area as a function of time and the number of layers in the coil.
Participants note that the original approach may not be suitable due to the nature of the problem involving a rotating coil rather than a linear rod. There is also mention of needing to clarify the number of loops in the coil and how the area changes with time.
mayo2kett
The coil of a generator has a radius of 0.14 m. When this coil is unwound, the wire from which it is made has a length of 5.4 m. The magnetic field of the generator is 0.10 T, and the coil rotates at an angular speed of 35 rad/s. What is the peak emf of this generator?
so i have:
r= .14m
L= 5.4m
B= .10T
w=35 rad/s
now i thought i would do:
emf= BLv
v=rw... v= .14m(35 rad/s)
emf= (.10T)(5.4m)(.049m/s)= .02646
and peak emf= (square root 2)(emf)= .0374...
this problem is wrong the way i tried it, but I'm not sure what i should do differently
so i have:
r= .14m
L= 5.4m
B= .10T
w=35 rad/s
emf= BLv
The induced EMF (across the ends of the rod) due to the motion of a rod of length 'l' and velocity 'v', in the presence of a magnetic field of strength 'B' is Blv. So this formula is not applicable here as there is a rotating coil and not a rod.
To solve this problem, go from the definition of Farady's law.
By Farady's law, Emf induced = -d(Magnetic Flux)/dt
Let the magnetic field make an angle theta with the area vector of the loop at any time 't' such that at t=0, theta=0.
So the Magnetic flux enclosed by the loop is = [itex]n B.A[/itex]
where n is the number of loops, B is the magnetic field and A is the area of the loop.
[tex]= (n)(B)(A)(\cos\theta)[/tex]
So, the EMF induced will be
[tex]=\frac {-d[(n)(B)(A)(\cos\theta)]}{dt}[/tex]
From this, can you calculate the EMF as a function of time and from that the peak value?
(You will have to find the relation between 'theta' and 't' as well as the value of n)
The coil is rotating in the field. The flux is thus changing and this causes the electric field in the coil.
[tex]\Phi = AB[/tex], B is constant but A is changing. Can you find A as a function of time?
[tex]E = -N \frac{d\Phi}{dt}[/tex], so you will also need to find N - the number of layers in the coil.
Just find [tex]\frac{dA}{dt}[/tex] and the biggest problem is probably solved.
thanks guys... you really helped me
10K
