Thread Closed
selections
Share Thread Thread Tools
Jul31-05, 02:34 AM   #1
Wiz
selections
I am stuck on this prob.....16 men are seated along a round table....in how many ways can i select 7 out of em such tht none of the selected individual were sitting next to each other?...
thanks
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Jul31-05, 04:24 AM   #2
In how many ways could you select 8 men? In how many fundamentally different ways (that is, without being able to rotate/flip one into another)can you select 7 men?
Jul31-05, 05:14 AM   #3
Wiz
i dont get u.....wht are u trying to say??.are u challenging the question or asking me a question which i myself posted on the forum?...what??
Jul31-05, 05:31 AM   #4
selections
Hmmm...I was trying to be pedagogical. See if I could point you in the right direction by asking some slightly different questions, rather than just stating the solution.
Another try: We have to select 7 persons with gaps (of at least one person) between them. This is equivalent to selecting 7 gaps (of at least one person) with exaclty one person in between. Now, in how many ways can you distribute the remaining 9 persons over the 7 gaps? We've got two different cases:
(1) We've got a gap of three persons, like: #000#0#0#0#0#0#0 (where # denotes selected). In how many ways can you do this?
(2) We've got two gaps of two persons, like: #00#00#0#0#0#0#0. In how many ways can you do this?
Jul31-05, 05:38 AM   #5
By the way: I get 14 + 42 = 56 possible ways.
Jul31-05, 06:17 AM   #6
Wiz
hmm...i get ur method..but ur ans is wrong..check it again..in the meanwhile i'll give it another shot..do post ur corrected ans...thanks.
Jul31-05, 06:50 AM   #7
Oh yes, I see, I made a mistake.
(1) In this case the selection is characterized by the position (of the middle person) of the gap of three. So there are 16 different possible selections.
(2) Now the selection is characterized by the position of the two gaps of two persons. The 'first' gap (of two) can be chosen arbitrary, so 16 possibilities. The second gap (of two) can be chosen from the 7-1=6 remaining gaps between selected persons. Now we have to devide by two because the gaps (of two) could interchanged to yield the same selection. So we get 16 x 6 / 2 = 48 possible selections.
Conclusion there are 64 possible selections.
Aug1-05, 11:39 AM   #8
Wiz
ok thtz correct.....but is there a way to generalise it??...say selection of r persons out of n ppl??.(in the same prob)
Aug2-05, 11:11 AM   #9
Recognitions:
Homework Helper Homework Help
First, build a matrix like
[tex]A = \left[ \begin{array}{ccccc} a_{11} & a_{12} & a_{13} & a_{14} & . . . \\ a_{21} & a_{22} & a_{23} & a_{24} & . . . \\ a_{31} & a_{32} & a_{33} & a_{34} & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Where [tex]a_{1j} = 1 [/tex] and [tex]a_{n1} = 1 [/tex], and define : [tex]a_{ij} = a_{(i - 1)j} + a_{i(j - 1)}[/tex]
Your matrix will look like:
[tex]A = \left[ \begin{array}{ccccc} 1 & 1 & 1 & 1 & . . . \\ 1 & 2 & 3 & 4 & . . . \\ 1 & 3 & 6 & 10 & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Problem: n people in a round table. No 2 selected people sits next to each other. Select p people.
Calculate: [tex]\delta = n - (2(p - 1) + 1)[/tex]. Then the total number of ways is :
[tex]C = a_{\delta p} + \sum_{x = 1}^{\delta} a_{xp}[/tex]
I wonder if anyone has discovered this. Anyway, if noone else has. Let’s call it ‘The little theorem of Viet Dao’.
EDIT : This formula can be horribly wrong if there is no way to select.
Viet Dao,
Aug2-05, 11:52 AM   #10
Wiz
i understood absolutely nothing in ur previous post......could u plz explain??....
Aug2-05, 11:30 PM   #11
Recognitions:
Okay, a matrix m x n is defined as:
[tex]A_{m x n} = \left[ \begin{array}{ccccc} a_{11} & a_{12} & a_{13} & . . . & a_{1n} \\ a_{21} & a_{22} & a_{23} & . . . & a_{2n} \\ \vdots & \vdots & \vdots & \vdots & . . . \\ a_{m1} & a_{m2} & a_{m3} & . . . & a_{mn} \end{array} \right][/tex]
[tex]a_{ij}[/tex] 0 < i < m, 0 < j < n is one item in the matrix. For example, i = 1, j = 1, then you will have [tex]a_{ij} = a_{11}[/tex]
And my matrix will have [tex]a_{1j} = 1 \mbox{ and } a_{i1} = 1[/tex]
So it will look like:
An item [tex]a_{ij}[/tex] is the one that lies on the i row, and the j column of the matrix.
[tex]A = \left[ \begin{array}{ccccc} 1 & 1 & 1 & 1 & . . . \\ 1 & a_{22} & a_{23} & a_{24} & . . . \\ 1 & a_{32} & a_{33} & a_{34} & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Then I say : [tex]a_{ij} = a_{(i - 1)j} + a_{i(j - 1)}[/tex]
Example : [tex]a_{22} = a_{12} + a_{21} = 1 + 1 = 2[/tex]
[tex]a_{23} = a_{13} + a_{22} = 1 + 2 = 3[/tex]
The item [tex]a_{ij}[/tex] is the sum of the item above it and the item to the left of it.
And so on, so my matrix will look like:
Then I calculate : [tex]\delta = n - (2(p - 1) + 1)[/tex]. There are 2 cases:
1. [tex]\delta \leq 0[/tex] : No selection.
2. [tex]\delta > 0[/tex]:
Then the number of selection will be:
It means:
[tex]C = a_{\delta p} + a_{1p} + a_{2p} + a_{3p} + ... + a_{\delta p}[/tex]
Where p is the number of people you want to select, n is the total number of people sitting on the round table.
* Solving your problem using my method:
[tex]\delta = n - (2(p - 1) + 1) = 3[/tex]
p = 7, n = 16 (This is what you have total people = 16, number of selected people = 7).
[tex]A = \left[ \begin{array}{ccccccc} 1 & 1 & 1 & 1 & 1 & 1 & 1. . . \\ 1 & 2 & 3 & 4 & 5 & 6 & 7. . . \\ 1 & 3 & 6 & 10 & 15 & 21 & 28. . . \\ \vdots & \vdots & \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
So you will have:
[tex]= a_{37} + a_{17} + a_{27} + a_{37} = 28 + 28 + 7 + 1 = 64.[/tex]
So there are 64 different ways to randomly choose 7 people, in which in every 2 selected people, they don't sit next to each other.
You can try another number of people sitting on the table (n), and the number of selected people (p).
You can use this as a method to check your answer.
Viet Dao,
Thread Closed
Thread Tools
Similar Threads for: selections
Thread Forum Replies
Music selections please. General Discussion 25
solving problems about selections using combinations Set Theory, Logic, Probability, Statistics 1
Top formats for your car radio selections General Discussion 11
