Angle between colors - dispersion
  • Thread starter Thread starter BDR
    Angle Dispersion
The discussion revolves around a problem involving the dispersion of light as it transitions from polystyrene to air, specifically focusing on the yellow and green wavelengths of light. The participants are exploring the application of Snell's Law to determine the angle between the two colors upon emergence.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of Snell's Law for calculating the angles of refraction for different wavelengths. There are questions about the correctness of calculations and the need for refractive indices specific to each wavelength.
Some participants have provided guidance on the calculations, suggesting steps to solve for the angles of refraction and how to find the angle between the two colors. There is an ongoing exploration of potential errors in calculations, but no consensus has been reached regarding the correct approach or results.
There is an emphasis on the need for accurate refractive indices for the specific wavelengths involved, and the original poster expresses uncertainty about their calculations without providing detailed workings. The expected outcomes are mentioned, but the discussion remains focused on the process rather than the results.
BDR
(a) A narrow beam of light containing yellow (660nm) and green (550nm) wavelengths goes from polystyrene to air, striking the surface at a 30 degree incident angle. What is the angle between the colors when they emerge? (b) How far would they have to travel to be separated by 1.00 mm?
I need some guidance on if i am working the problem right! Do i use Snell's Law?
1.49sin30 = 1.000293sin(angle)?
Yes, use Snell's law of refraction. But you need to know the refractive index for each wavelength. The angle of incidence is the same (30 degrees), but the angle of refraction will be slightly different for each wavelength.
Here is what I'm doing!
Yellow: 1.492sin(30) = 1.000293sinθ
Green: 1.493sin(30) = 1.000293sinθ
When I do the calculations i am not getting the correct. The answer is suppose to be 0.043 degrees and 1.33 m. Where do you think I am messing up the calculations?
Beats me since you didn't show your calculations!
Using those same equations I get 0.043 degrees, so I'm not sure where you went wrong. Try this: (1) Solve for the angle of refraction for each color; (2) Subtract those angles to find the angle between the two refracted colors.
  • · Replies 207 ·
16K
12K
